i know this is an age old topic for us but i need some help.....here are my symptons......
-smoke comes out of exhaust at idle -lot-o-smoke at low revs -oil coming from distributor leaking on tranny -oil on spark plugs -oil pan leaking?? -refill oil every month any help would be appreciated......i looked @ www.4thgenerationcivic.com for the oil pan and i think new gaskets will help for the spark plugs
The name's Adrian 1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills 2006 G35 Coupe 6MT - Stock 2011 CR-Z - Stock |
sounds like you need a valve cover gasket ,oil pan gasket ,maybe a distributor o ring, new piston rings.
Your head gasket may be going. Do you feel a power loss? It is also possible your piston rings are starting to go. Smoke out the tail pipe can come from that. Bummer that it is causing such a problem.
If you are ever in the southwest desert and you see a dust storm coming your way, when I see you I'll wave hello. My Home Page: Under Heavy Construction |
where would i get a distributor o-ring?? and how much are pison rings?? are they hard to put on myself? i don't feel a loss of power though....
and something else to add..whenever i rev there is always black stuff on the ground from my exhaust
you definatly have some major problems, with those symptoms, id say:
stuck or bent exhuast valve, bad dizzy seal and or cam seal, possible head gasket leak, pistons rings. pistons rings are not a job for a beginner to do, it requires taking the entire engine apart, and quite possible out of the car. hope all turns out well.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
sounds like a good excuse for a d16z6
AF Bay Area Crew ![]() 97 Toyota T100 xcab 3.4l v6 5spd 2wd |
also remember, white smoke is water/antifreeze, oil is blueish, and way too much fuel is black
Sounds like you need a rebuild, a rebuild kit from honda will have all you need, get a ring kit and oil pan gasket also...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
2002 Acura TL Type S 1991 Honda Crx Si |
sounds like ur engine is a bit "Worse for Wear" it would be easier to change the engine than mess with wot u have :-/
Jim - Your Resident EDM Biatch B16A1 I/H/E 4TH GEN UK SITE Honda Civic EE9 1.6-i VT |
what side of the spark plug is the oil if it is on the combustions side you need rings
95 b18b new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned |
perform compression test
i guess this means no more trip to OR
"hi! my name is Lady, and i'm a HONDA-holic" ..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose! ![]() *~ I <3 the G Ride ~*~ I <3 OLD SKooL |
