Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 08-29-2004, 04:46 PM
kingdavidz kingdavidz is offline
99 Gt Burnin oil like mad
ive got a 99 sunfire gt that burns oil like a mother trucker ,,, what is the cause of this and what can i do to fix this.....no leaks or anything just burning like crazy
Old 08-29-2004, 05:52 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 99 Gt Burnin oil like mad
How many miles are on the engine? There are a lot of things that can cause and engine to burn oil. You could have a bad intake manifold gasket, bad rings, a leaking front or rear main seal (you would see leaks not smoke) and you could have bad valve seals althought most of the smoke from these would be seen at start-up although they will cause a car to burn oil if they are too bad. If your car is high mileage you might try a product called Restore. It can stop a certain amount of oil burn by filling in scratches in the cylinder walls, but if it is burning like you say it is then there must be a problem elsewhere. There are other products on the market that will do the same thing. Hope these ideas help you diagnose the problem.
Old 08-29-2004, 08:53 PM
thanks
there are 132,000 km's give or take,,,, but thanks for the suggestion, i know of a product from lucas oil engine treatment as well as restore...but thanks for the suggestions...i could smoke a salmon on it one day....does really blow alot of smoke but i do see alot of blackness in the exhaust..
Old 08-30-2004, 07:10 AM
Pontiac Guy
The blackness can be caused by a rich condition in the fuel air circuit. The smoke from oil burning will usually be blue in color. Usually if you are burning oil the black residue will be oily to the touch. If it isn't oily then check to see if the fuel air mixture is correct.
Old 08-31-2004, 03:50 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Does the car run bad or is it just consuming oil? IF it's running bad, I would guess you have a cracked head or at best a blown head gasket. These would cause excessive oil consumption w/o producing blue smoke.
