Old 12-28-2003, 08:32 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Re: Help! weird buzz when acclering
Ok:
SiR: Noise comes from passenger (RHD remember) side. Not the ECU, not the VSS (I replaced mine) not a loose heat shield or anything else jangling. It's not the PS pump, alternator or A/C pump (repbuilt, replaced, disconnected respectively. The only thing I can think of is it's the injectors
Cheers
Pete
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 12-28-2003, 08:35 PM
95pathfinder 95pathfinder is offline
Mine does it when the engine is under a load or working hard, ie: take offs, hills. If I don't accelerate and am in the right gear or coasting it doesn't do it. It sounds kinda like a motorcycle or a baseball card in the spokes of a bike. You said that if it does it under a load that it narrows down what it could be substantially. I'm afraid it'll be engine. How can I check? What about the alt or comp? How do I check those?
Old 12-29-2003, 06:51 PM
Someone online told me that nissans are noutorious for developing a loose timing chain at about 80 thousand miles. He said that I should install a new timeing chain. My SUV uses dual chains on a V6, a kit is about 140 bucks. It should be an easy do it yourselfer. He said that my tourqe converter is probably bad and that I should take it out and have it rebuilt for about 80 bucks. I hope this helps.
Old 12-30-2003, 06:43 AM
Setanta's Avatar
You need to increase your knowledge of Hondas :? They ALL run timing belts, not chains. Torque convertors are for autos only, I don't think there are too many auto ED/EF drivers here.
'bout what you'd expect from an SUV driver though :P
'99 PY DC2R
'85 BBS BMW E30
Old 01-03-2004, 12:46 AM
I found the problem! It was an exhaust leak near the engine, at the manifold.
One speaker buzzing when turned on, others are fine Destrozado Car Audio 3 09-02-2010 09:35 PM
91 tracker has miss when acclerating versatech Tracker 2 07-10-2008 02:17 PM
Sputter when acclerating too fast. seldomo19 Park Avenue 1 11-24-2005 05:15 PM
vibration from front end when acclerating dan619 Altima 1 08-29-2005 07:48 PM
Help! weird buzz when acclering onetrueshyguy Engineering/ Technical 28 12-10-2002 06:07 PM
