Old 09-30-2002, 06:36 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Cool, thanks!
Here's the pic I snapped of it. You can see where the solder bridged between the two connections with the red-arrows:
Old 10-03-2002, 08:34 PM
coolblue's Avatar
coolblue coolblue is offline
similar problem i guess..
but i checked the ignition and it looks fine...
here's what happens. When i bring it down to an idle, like before i turn the car off, after a drive. I can smell something burning, almost like plastic..
yes i did install a '89 Si cluster, and the smell began soon after i did so..
so i'm planning on replacing the standard cluster to see if the smell still happens..
anyways.. is there anything else that could be making a stink like this?
i drive an '89 hatch dx.
Old 10-04-2002, 12:22 PM
coolblue's Avatar
the smell is definetely coming through the vents... and you can sometimes smell the burning while standing outside the car...
Old 10-07-2002, 05:34 PM
Brad McCoy Brad McCoy is offline
Originally posted by ci5ic
Cool, thanks!
That is the same place that mine overheated, only my solder fell into the fuse cover.
The top arrow in your photo is the wire that looked burnt on my wire harness.
Old 10-07-2002, 06:23 PM
tbk49's Avatar
tbk49 tbk49 is offline
Send a message via MSN to tbk49
haha smoke comin through the steering wheel?? thats crazy sounds like a comedy glad you got ur problem fixed
blah
Old 10-07-2002, 06:56 PM
ci5ic's Avatar
Yeah, it's just like a comedy, except it wasn't funny, and nobody was laughin'... hehehe
But my problem isn't fixed. See my thread titled "help again!" for more info.
Old 10-09-2002, 10:20 AM
kaytec4door kaytec4door is offline
Talking
i have a friend that had the same prob. when the smoke would come out of her steering wheel and the tac would jump. well what happens is carbonizing of the ignition switch. the car would actualy like turn off for a second but go back on, this would cause your tac to jump. and the smoke comes from the heat and the sparking of the switch. u can either clean it or buy a new one.
:smoker2:kaytec4door:smoker2:
mods done: AEM cold air intake,
ractive racing cat,
ractive axel back exhaust,
NGK plugs,
nuespeed cross-drilled rotors,
EBC the green stuff pads,
projecter headlights,
clear corners,
carbon fiber tails,
Z3 fenders,
adjustable coilovers,
Konig flatline rims with dunlop fm901 (17*7),
full complete sound system with two 10'' subs,
kenwood 600w amp,
punch cap,
pionner speakers all the way around,
full custom interior paint job,
reverse indiglo guages,
aluminum gauge bezel,
d16a6 head swap polished,
4-2-1 ceramic coated header,
:finger4: proud member of team kay tec:finger4:
Old 10-09-2002, 10:22 AM
my friend had the same prob. jumpin tach and the smoke. it the ignition switch. it carbonizes and causes prob with the car starting and smoke.
ractive racing cat,
NGK plugs,
clear corners,
carbon fiber tails,
Z3 fenders,
kenwood 600w amp,
punch cap,
Intermittent white smoke. WTF? 9396 ULTRA Suburban 6 09-29-2006 10:17 AM
my vent air smells like black and mild smoke.... wtf??? Young Chuck D Cavalier Problem Diagnosis 6 07-20-2006 12:02 PM
Wheel Help //// Smoke... Asap Help blindfoldedhope Probe 0 11-13-2004 12:13 AM
Can't rev past 2500RPM and balck smoke! WTF?? Import2nr99 Off-Topic 13 08-28-2004 09:20 AM
Help...smoke coming out of intake manifold? ddustin Integra 0 11-07-2003 09:42 PM
