Old 09-28-2002, 11:09 AM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
yo, 91civicDXdude we should meet up next time im up in kc, thats like a 45 min drive from where you are.....i wanna race! hhehe we have the same engine so it would be a pretty close race, it would prolly depend soley on the driver
Old 09-28-2002, 01:11 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Originally posted by Killa_CRX
oh, so by wiring harness you mean instead of having the wires resoddered, putting together two connecting ends with which to plug the DX and the sohc vtec ECU together?
yes, one end goes to your dx harness and the other end into the p28 ecu.
the pics are too big...so here are 2 thumbnail pics
you can find the full size at my swap page
on the big pics you will see 8 wires wrapped in tape. those are the 8 wires to be extended...the rest is plug n' play. as you can see, much easier than 50 wires.
the 8 wires go to:
(4) go to 4 wire o2 sensor
(1) to knock sensor
(1) to vtec solenoid
(1) to check engine light
(1) ? dang it i forgot
i can't remember the last one off the top of my head...maybe gunnmen does
ami
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 09-28-2002, 01:14 PM
Bleebdat Bleebdat is offline
Send a message via AIM to Bleebdat Send a message via Yahoo to Bleebdat
(1) to knock sensor
________________
8 wires although is dang it i forgot a tech term?
Old 09-28-2002, 01:38 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
the 8 wires go to:
(1) to knock sensor
ami
Ok, so the 8 wires are extra wires from the p28 ecu that the DX harness wouldn't normally have, right? Just need to be extended from the wiring harness to thier proper places?
Wiring harness looks most worth the money now looking at it! Wouldn't want to try that myself
But that doesn't take care of the fact that the DX has dual point fuel injection does it? Would I still have to add anything for that, or does using the p28 ecu take care of that lil' problem?
Sorry so many questions, but I think I am going to try and do this swap on my own, so I'm trying to get everything pretty exact, as far as what I know and cannot understand from all the "how to do" websites you've provided.
And I'm still unsure about the DX throttle cable... cause I know I read somewhere (can no longer remember nor find where) that the DX has an abnormally long throttle cable, and one from an Si or HF has to be used... is this true, or does anyone know for sure?
Honda Enthusiast
Old 09-28-2002, 01:43 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
I dont remember the 8th wire either, i have only talked to Ami about it, never seen one.The p28 ecu will run everything else with that adapter from Jon.As for the dx throttle cable you can use it, i used mine, just takes a little creative looping to get it to lay right.
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 09-28-2002, 01:54 PM
91civicDXdude's Avatar
You can use the throttle cable of off any 4th gen model that has multi point fuel injection stock. I used the cable off of a CRX HF and it works fine.
already been answered bro
Old 09-28-2002, 01:56 PM
yeah i go to KC on a regular basis. are you still using the DX tranny? we just might have to do that heh:frog:
Old 09-28-2002, 01:58 PM
Killa_CRX's Avatar
When Civics Attack!
Due to what I said I've read, I didn't find your answer informative enough.
But I understand now, thanks to gunnmen01.
Honda Enthusiast
Old 09-28-2002, 06:11 PM
nah, im using the a6 tranny, u still on a dx?
Old 09-28-2002, 07:23 PM
Alpha Racing EF9's Avatar
Alpha Racing EF9 Alpha Racing EF9 is offline
knock sensor?
P28 ECUs don't require a knock sensor. Only 92+ B-series VTEC,98+ CRV,and 96+ EX (possibly HX) ECUs do.
Also,if you do use the fuel injectors off that newer engine,you will need to bypass the fuel injector resistor on Si models.
Your firewall will also be free of that MAP sensor and EVAP purge solenoid (one near the throttle body)
Z6 block/Y8 head.Pardon the mess,it hasn't been driven over 4 years now
where the injector resistor box used to sit
Ed
1998 - Taken off the road after the engine went.
2002 - Resurrection.Still under construction.Assembling my NA B20-VTEC soon,still a lot of other crap to do.
My homepage
Alpha Racing - IDRC SR-1 and All Motor class winners;interviewed on ESPN2;one of our Supra TT's in the Sprite "Girl Racer" ad
Race 101 -World's First 11-second watercooled NA VW
Old 09-28-2002, 10:36 PM
slammed....
yeah im still using the DX tranny.. sucks for accelerating man. when you hit 4th or 5th gear its like hitting a wall. it just dont accelerate any faster than that. i have to hope i can pick up enough speed by shifting at like 7100 rpm
Old 09-28-2002, 11:52 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
I like the DX Tranny. It doesn't accelerated as fast but when you are on the highway and after you hit 70 it rolls damn well.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 09-28-2002, 11:55 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
Since my Si Tranny got fucked up, i'm on a Hybrid Tranny its a ZC tranny and a Si final Drive I got all brand new gears also I love this baby! Its so sweet Plus, i only got it for 200 bucks cause there is a guy who had a ZC in his CRX, but put in a b20...... and he sold the ZC, but the tranny was sittin in his garage for a month, so i got it off his hands YAY!
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Whats needed for this engine swap. 4cyl to 5.0 Wuzzube Mustang Talk 0 11-15-2004 08:46 PM
89 Teg. LS swap vs. SOHC VTEC swap cornbread499 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 06-24-2003 10:21 PM
Parts for Sohc vtec head swap walt0023 '88 - '91 Civic | CRX | Wagon | Shuttlee 8 12-02-2002 11:19 PM
SOHC VTEC swap pics 91civicDXdude '88 - '91 Civic | CRX | Wagon | Shuttlee 15 09-09-2002 02:15 AM
