Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-13-2002, 04:16 PM
Grendel's Avatar
Grendel Grendel is offline
Originally posted by GSteg
a T3 turbo from some old Saab. they work good enough. get the manifold that is for your engine. theoretically, a T3 should bolt right on to the B-series exaust manifold. if you don't want to risk it, get a muffler shop to make one for you. they will cost less than name brand manifolds. the T3 has quick spool-up times and has the potential to make lots of power, but the price on one is pretty expensive.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1842746174
u can look on ebay and try to find some old porsche, volvo, saab, etc. cars. i was just showing an example of the ford 7.3 turbo how they can be used in a civic, etc. i didn't mean its the best one to go cuz the time it takes to spin one of those things is forever (you'll need lots of power in order to do so)
I think the turbo on my car is also a T3, look for a wrecked 280zx turbo at a junkyard, pull the turbo off it for cheap
-Grendel
Old 07-16-2002, 06:45 PM
Anarki_Renegades Anarki_Renegades is offline
I think our man needs to learn how a turbocharger is setup to begin with. He doesn't quite understand how a turbocharger helps increase power. Click here for some good articles on how a super/turbo charger system works.
Old 07-17-2002, 07:39 PM
Mugen_R's Avatar
Mugen_R Mugen_R is offline
Send a message via AIM to Mugen_R
I choose to go with the Turbo from a Ford 2.3L, which I belive is from the cobra/mustang. It works well with the integras, and it has better performance then other turbos, with a small wastegate allready with it.
thanks for all the answers, this was verry helpfull.
thanks agian to all.
Old 07-27-2002, 08:52 PM
Rob80 Rob80 is offline
Send a message via AIM to Rob80
which turbo?
you should look into a first gen mitsubishi eclipse turbo, 14B, with T-D05 flange. the can efficiently put out up to like 20 psi but they spool a little slow.
You could also get a 2nd gen eclipse turbo a T25 which spools very fast.
both of these turbo's are a very cheap alternative to the large T30 (Ok not that big but large enough)
Old 07-28-2002, 12:24 AM
sohcvtecrx sohcvtecrx is offline
if youre looking for a good site for some turbo information go to homemadeturbo.com. they have any info you need
Old 07-29-2002, 09:17 PM
5_LiTeR_EaTeR 5_LiTeR_EaTeR is offline
Send a message via AIM to 5_LiTeR_EaTeR
You will need to get an adapter for the manifold to the turbo. Get a t2 or t4 Turbo off ebay, Get an intercooler if you are not on a budget. People say you don't need an intercooler if you are pushing low psi but its still good to give you a denser charge. Go to a Muffler shop and have them custom mae a down pipe. Make sure they cut and weld peices together and not crush bend the piping for you will increase the restriction on the exhaust and increase spool time. Get a type of Fuel management system to work with the turbo get boost controller to make sure you are always in control of how many psi you are pushing get a blow off valve to release air when the throttle plate is closed. I would say you are looking around 600-900 bucks easily. Good luck!
VTEC WORKING FINALLY & HAULIN SOME ASS!!
If the shadow of your car is smokin' you it definately means you are smokin' someone else!!
KKK k24 Turbo on the way to the install!
You will need to get an adapter for the manifold to the turbo. Get a t3 or t4 Turbo off ebay, Get an intercooler if you are not on a budget. People say you don't need an intercooler if you are pushing low psi but its still good to give you a denser charge. Go to a Muffler shop and have them custom mae a down pipe. Make sure they cut and weld peices together and not crush bend the piping for you will increase the restriction on the exhaust and increase spool time. Get a type of Fuel management system to work with the turbo get boost controller to make sure you are always in control of how many psi you are pushing get a blow off valve to release air when the throttle plate is closed. I would say you are looking around 600-900 bucks easily. Good luck!
Stupid turbo question? Do a CT 26 turbo need a gasket seal or seal? DrifterRZero MR2/MR-S 2 11-19-2010 02:52 AM
Tranny questions and turbo questions... Marc-OS 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 05-08-2004 01:40 AM
Turbo Question criscross79 Impreza/9-2x/Outback Sport 8 01-28-2002 04:47 PM
Turbo question Initial_E 911 4 12-28-2001 06:51 PM
Turbo question? MDurs Engine 3 12-05-2001 06:36 PM
