Old 11-12-2004, 10:20 AM
GvEman's Avatar
GvEman GvEman is offline
Re: --- '37 Ford Coupe ---
Awesome! i like it alot! it must be one of the best looking rods built here on af!
Best Regards
Anton
Old 11-12-2004, 10:53 AM
rx7king's Avatar
rx7king rx7king is offline
thats awesome that window looks really cool. what color are you thinking of?
Old 11-12-2004, 11:08 AM
kunta's Avatar
kunta kunta is offline
Fantastic modification on roof and hood.
love those cool wheels.
Old 11-21-2004, 10:18 PM
cwmax cwmax is offline
I got a lil bored sanding and filling and sanding, sanding .... on the body. So I assembled the chassis.
It is pretty much as it comes in the kit with the exception of light mods to lower the suspension. Removed some chassis in the rear and mounted the center chunk on top the cross member. Also added some blocks under the front cross member. I also scratch built the front coil overs. I didn't intend to from the start, but after breaking one of the plastic coil overs off the cross member I decided to give it a shot. Pretty happy with the results. The brakes are Pegasus.
I also assembled part of the engine. It still needs wires and hoses etc. I will also scratch build the exhaust , I don’t like the stock ones.
I decided on the colors for the car, two-tone. The light color is Dupli-Color Champagne and the dark is Dupli-Color Black Cherry. I need to work on my painting skills a lil. The colors were sprayed over black primer, I should have used gray primer, I expected the Champagne to be lighter.
Thanks for looking ...
Till Next ...
Old 11-22-2004, 01:52 AM
WeaPoN [X]'s Avatar
WeaPoN [X] WeaPoN [X] is offline
Great combination. Very classic and sleek looking. The chassis alone looks menacing. This is going to be a show stopper.
JeFF
Old 11-22-2004, 02:38 AM
Wheelin75r's Avatar
Wheelin75r Wheelin75r is offline
Old 11-22-2004, 06:33 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Very Sweet. Hows that grill coming along? If I can get an idea of how to build mine I might actually finish my '37.
-Mike
Old 11-22-2004, 11:06 AM
GvEman's Avatar
coolnes! looks sweet dude!
Best Regards
Anton
Old 11-22-2004, 11:14 AM
GT-Alex's Avatar
GT-Alex GT-Alex is offline
Send a message via MSN to GT-Alex
The chassis looks fine !
Old 11-22-2004, 12:04 PM
ONEBADMK8's Avatar
ONEBADMK8 ONEBADMK8 is offline
Banned
Looking Great!
Old 11-22-2004, 12:50 PM
Re: Re: --- '37 Ford Coupe ---
I havn't got to that point yet. I do know how I will do it. I want to get all the heavy sanding done before I build the grill as it will be part of the body and delicate. Since I decided to make the hood one piece (top and sides ) it would be impossable to lift the hood off pass the grill. So I will build the grill onto the body then have the top 1/2 attatched to the hood and bottom to the fenders. I'll definetly show the progress on it.
Thanks all for the comments, here's a pic of the coilover
I used styrene rod, some craft wire from wallyworld for the spring and the shaft is a loop antena from an old wireless security door transmiter .
Old 11-22-2004, 03:21 PM
mike@af's Avatar
That is one kick ass coilover.
-Mike
Old 11-22-2004, 04:26 PM
blubaja's Avatar
blubaja blubaja is offline
Hey,
Dam! That chassis looks and suspension looks really nice so far. Do you think the pe grille set might help any? Keep up the awsome work.
Frank X.
Old 11-22-2004, 05:07 PM
Originally Posted by blubaja
Hey,
Frank X.
I didn't know there was a PE set for it. I did a search a while back but couldn't find one. I also figured the amount of modifying I would have to do to the PE set to make it fit the car, I may as well save the $ and build one from styrene rod.
It may work for Mike if the original grill profile is the same. Mine, the vertical profile is quite different.
Thanks for the thought
Old 11-22-2004, 05:28 PM
mike@af's Avatar
Re: Re: Re: --- '37 Ford Coupe ---
I've got the same grill dilema. Mines more sleek, and slicked back so the stock grill just looks ugly.
-Mike
