Old 03-07-2011, 08:28 PM
RepairJudge RepairJudge is offline
Send a message via ICQ to RepairJudge
Re: 2002 ABS and Brake lights coming on?
I've used that scan tool several times. It's pretty decent.
Car Repair Estimate Auditing Service - Don't Pay Until We Okay.
Old 03-07-2011, 09:02 PM
tempfixit tempfixit is offline
RepairJudge, have you found anyvehicles that it does not work on?
thanks
Old 03-08-2011, 12:32 AM
WindstarMommy WindstarMommy is offline
Tempfixit, not to interrupt again but this link lists all the vehicles it will work on.
Just click on the words "coverage guide" in that rectangular box to download/open up the info in pdf form.
http://www.amazon.com/Actron-CP9449-...9565616&sr=1-2
Hope this helps.
Old 03-08-2011, 02:22 AM
Hope this helps.
I had read the coverage guide before, but just curious if RepairJudge came across any vehicle that was not on the list that it did or did not work on..
thanks
Old 05-03-2011, 11:59 AM
CnlK CnlK is offline
Well my abs light reappeared, didn't seem to be related to any malfunction of the speedometer this time. Without access to an abs scanner, thought I would check wheel sensors for continuity and AC voltage output. After reviewing different threads on this forum I couldn't find any with a definitive ohms reading. I found all but my front left sensor had readings from 1820 to 1840 ohms. Front left was open and would occasionally read 13K ohms. Was able to get a very slight AC voltage reading of .1 to .3 volts when spinning rear drums, couldn't spin front rotors fast enough by hand to get any type of reaction. Had to adapt some jumper wires with a female pin connector to plug into wheel sensor pins. New sensor also had an ohm reading of 1825 ohms. Installed a motorcraft part number (BRAB 108) Ford #
XF2Z-2C205-AC from Rock Auto $50 delivered, Motorcraft site wanted around $80.
After driving about 70 miles, abs light remains off. Destroyed sensor when removing, end cap broke and was stuck in bore of steering knuckle. Spent about 30 minutes removing stuck plastic cap and cleaning out bore so that it was large enough again to install new sensor without forcing and damaging, take care not to damage toe ring/trigger wheel when cleaning rust from bore. I'll have by fingers crossed that the dreaded abs light doesn't reappear.
2014 Chevy Equinox 2.4L, 2010 Grand Caravan 3.8L
emergency brake light comes on freakyfire05 ZX2 8 02-11-2010 10:19 AM
98 bleeding brakes/ABS light comes on PHXAuto Intrigue 2 09-28-2009 08:51 AM
Battery Light and Brake light come on and A/C fan doesn't work Kayleigh Rodeo | Passport | MU 14 06-27-2009 03:22 PM
Alero ABS, Low Trac, Service Light and Brake Light coming on... Laz174 Alero 5 02-07-2007 09:13 PM
abs and track light comes on albert Young Grand Prix 10 09-09-2005 10:04 AM
Tags
abs , brake , lights , warning
