Go Back   Automotive Forums Car Chat > Oldsmobile > Intrigue
Old 09-18-2011, 01:57 PM
onanboy onanboy is offline
Cool Proper jacking
Hopefully this is an easy one. What is the proper way to use a floor jack on a 1998 Intrigue? By that I mean, where should it be positioned, can you directly apply the jack to the frame or do you need something more malleable between the jack and the frame, and where to put the jack stands after I get it up. For reference, I am going to try to do new front brake pads and rotors. Thanks.
Old 09-19-2011, 01:06 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Proper jacking
Do you have an owners manual? That will illustrate where to jack the car.
Old 09-21-2011, 01:27 AM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Re: Proper jacking
If you have the original jack, the proper location for that car would be behind the front tires...look under the car...behind the front tires and you will see a pinch weld hanging down...it runs the length of the distance between the tires (front to back)...well if you carefully you will see where (approx) 5 inches of that pinch weld hangs a little bit lower than the rest. That is where you put the ORIGINAL jack. The original jack has a slot for that pinch weld to fit into.
If you have a floor jack I would jack it up right underneath the engine cradle. Right where the cradle frame bolts go into the bottom of the car. As-in placing the jack right beneath one of the cradle to car bolts and lift the car at that point. I would only try to do ine side of the brakes at a time and I would NOT try to lift the car (in this method) high enough to fit a jack stand underneath it. Id lift the car barely enough to pull the tire off and change the pads one pair at a time. I'd leave the car on the jack, but that's just because I wouldnt be getting underneath the car and changing pads in that kind of car is a 20 minute job. Tops...
The Following User Says Thank You to Tony Silva For This Useful Post:
onanboy (09-25-2011)
Old 10-02-2011, 03:19 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Proper jacking
As stated you can use the engine cradle, lower control arms, and pinch welds (if they arent rusted like mine). I usually go on the frame more towards the center on each side when jacking up, and the put jack stands on the pinch welds. Just becarefull for things like fuel and brake lines. and chock the back wheels. You will be fine.
-2000 Grand Prix GTP 170,000mi (daily driver)
-2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal)
-1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix])
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
"I'll Keep my Guns, Freedom, and Money. You can Keep the Change!"
----->>>>> Did You Know? <<<<<-----
The Following 2 Users Say Thank You to tblake For This Useful Post:
Moppie (10-03-2011), onanboy (10-03-2011)
Old 10-03-2011, 10:15 AM
Thumbs up Re: Proper jacking
I much appreciate the advice. The last thing I wanted to do was to damage the frame at its weak points with poor floor jack placement.
98 hond accord ex front centeral jack point harryhk Accord/TSX/Accord Hybrid 12 07-03-2011 12:46 PM
Proper way to jack up Intrigue? sparcx Intrigue 16 05-18-2010 10:58 AM
Proper Jack to use on Tahoe drick37 Tahoe 4 03-07-2010 03:11 PM
Properly jacking up the front susman28888 Bonneville 2 04-28-2007 03:26 PM
proper jacking locations shaner123 SC/SL/SW 5 10-27-2005 08:25 AM
Tags
floor , fram , jack
