Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 02-11-2010, 05:57 PM
drick37 drick37 is offline
Proper Jack to use on Tahoe
Quick question, I've been using a 2 1/4 ton jack on my Tahoe with no problem until my neighbor informed me that my Tahoe curb weight is about 5500 lbs. I told him that since I was not supporting the entire vehicle on the jack that the 4500 lbs that it supports should be fine and I am using 2 1/4 jack stands, I NEVER support the whole vehicle, just one tire at a time while doing brakes. Should I get a bigger jack?
Old 02-11-2010, 08:43 PM
roadrunner2 roadrunner2 is offline
Re: Proper Jack to use on Tahoe
NO.
GM doesn't even supply individual jacks in their vehicles to carry that much weight.
All you need to be is cautious when using your jack that it doesn't slip and/or cause damage.
I trust you are blocking the other wheels while the vehicle is up on the stands?
Think SAFETY FIRST.
The problem with doing nothing is not knowing when you're finished.
Old 02-11-2010, 09:03 PM
Yes, I am. Thanks for the info.
Yes and safety first.
This forum is a great place for info.
Old 02-12-2010, 05:31 PM
j cAT j cAT is offline
as mentioned just look at what GM gave you , and compare with your jack..
you have the correct capacity...I however don't trust jack stands...also on pavement they mess the surface up...I prefer solid oak blocks...
I use 12 ton bottle jacks most of the time to jack up the truck/tahoe vehicles just because of the greater jacking height...
Old 03-07-2010, 02:11 PM
CraigZerch CraigZerch is offline
I think you are fine, your neighbor is probably just overly cautious.
