Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-28-2007, 12:12 AM
susman28888 susman28888 is offline
Exclamation Properly jacking up the front
I would like to change my own oil, I know how to change the oil and everything I just want to know when you jack the front of the car up, to change the oil, front brakes ect. do u jack it from the center of the car and if so, where in the center, or do u jack it from the jack points as if your changing a flat. any help would be appericated!
thanks,
leeland
PS; 2000 bonneville pontiac 68 k
Old 04-28-2007, 08:05 AM
maxwedge maxwedge is offline
A990 racer
Re: Properly jacking up the front
Welcome to AF. If you jack up from the side you are tilting the oil pan so a full drain will not happen. Jack it up fron the front under the front subframe crossmember. Jack stands and a floor jack are required here.
Old 04-28-2007, 02:26 PM
ChemMan ChemMan is offline
For changing oil, I've found nothing easier than to buy a pair of ramps to drive the car onto, although I'm assuming you have a driveway to park the car on. I recommend Rhino ramps, which are made of plastic, so they are lightweight but are surprisingly strong.
2010 Mazda CX-7 2.5L 12000 miles
2003 Chevy S10 Extreme 4.3L 57000 miles
1995 Buick Lesabre Custom 86000 miles RIP
2002 Pontiac Sunfire SE 130000 miles RIP
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
