Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 01-22-2004, 06:00 PM
ronjonprobe93 ronjonprobe93 is offline
Torque advantage
is 10 extra Ft lbs of torque a huge advantave in racing if the horsepower of two cars are the same but the one with the extra torque is 200 lbs heavyer?
Old 01-22-2004, 06:25 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
Re: Torque advantage
no advantage at all.
10 ft lbs., but 200 lbs. heavier?
he'll probably still lose the race... honestly.
Old 01-22-2004, 06:38 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Like flylwsi said, 10 extra ft/lbs of torque is a very small advantage, but 200 extra pounds of weight is a huge disadvantage.
Old 01-22-2004, 08:03 PM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
and just to muddy the waters...its not just about weight to power ratio...the powerband, and gear ratios will make a huge difference
the only way to find out for sure who is faster is to race
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 01-23-2004, 12:19 AM
Keitaro Keitaro is offline
Send a message via AIM to Keitaro
Can you explain about powerband\gear ratio? I didn't undderstand it.
Current game and Initial-D card(s) playing:
Version: 3rd
Car: Toyota Trueno GT-Apex (AE86) - Option A Full Tune w\AE101 engine.
Areas cleared: Every track and challenger defeated.
Bunta Level: Akina DH-1 and Iro DH-1.
Battle Points: 710,000+
Racer levels stars: 12 (With Aura.)
Akina Downhill Dry record time: 3' 10"
Note: Version 1 > 3 transfer. Set record times at local arcade on Version 1 (ex. 3' 04" Akina DH) and defeated V.1 a dozen times with this car.
Old 01-23-2004, 12:36 AM
ColeIketani's Avatar
ColeIketani ColeIketani is offline
Send a message via AIM to ColeIketani
I'm guessing this is a drag race correct?
2003 Hyundai Tiburon: Injen CAI, Mussa Single Exhaust, Sparco Four Point Harnesses, RRM Front and Rear Strut Bars, 22mm Rear sway bar, Shark Racing Pedals, Painted Rims.
Saving for: Either Big Brake Kit, lines etc, Tien Coilovers Sparco Speed Seat for driver side.
Old 01-23-2004, 01:08 AM
Neutrino's Avatar
Yaya Master
Re: Re: Torque advantage
this article will explain it better than i can
http://vettenet.org/torquehp.html
(\__/)
2turboimports's Avatar
2turboimports 2turboimports is offline
lets say for instance....1 car is an AWD impreza and the other car is an Integra GS-R.
the gsr has what, 170 hp, and we'll say 120 lbs. trq.
the impreza has 165 hp, and 165 lbs of trq.
they weigh in about the same, 2880 lbs.
(this is all off the top of my head, and i'm not sure the numbers are right, but it's just an example.
It would seem like the impreza would win...but because of the crappy gearing and total lack of top end, the gs-r eats up the 4 lengths the impreza puts on it to 65, then flys by at around 70 and pulls a few cars till around 95 when i'm in 5th and he/she's in 3rd or mid 4th.
Old 01-23-2004, 01:12 AM
sooo...the impreza is better geared for quicker 0-~60, and the integra a quicker ~50 - whatever.
but that's kinda a bad example i guess. argh..hopefully it helped some.
Old 01-23-2004, 01:32 AM
In other words, excellent torque is very good for low speeds, excellent horsepower is very good for top speeds.
Version: 3rd
Old 01-23-2004, 01:44 AM
Neutrino's Avatar
Yaya Master
no no its all about the torque curve and rpm...horsepower its just a function of torque..read the article behind the link i posted...it explains a lot
and the gearing matters since it determines how that torque is put down
(\__/)
Old 01-23-2004, 03:17 PM
exactly.
Old 01-23-2004, 05:02 PM
carrrnuttt's Avatar
carrrnuttt carrrnuttt is offline
Horsepower is a derivative of Torque.
Horsepower = Torque * RPM / 5252
Learn yourself : http://vettenet.org/torquehp.html
EDIT: Ooops. Didn't realize you posted the same link already Neut.
2002_Nissan_Maxima_6-speed
Old 01-23-2004, 06:01 PM
1QUICK2 1QUICK2 is offline
Let use this example. My car weighs 3100lbs, when I first got it with minor mods it made 230lbs of Tq, thus has 13.47lbs of Tq per pound of weight. Other side if it weighed 3300lbs and had 240lbs of Tq, it would make 13.75lbs per pound of weight. So in this case the more weight would be better.
I just wanted to sound scientific one time in my life.... Thank you all for being a part of this.
93 MR2 Turbo-.20 over JE pistons,T3/04E 57 trim w/.63 AR,Intake,Greddy profect b spec 2 BC, APEX'I GT spec exhaust,Apex-i S-AFC, Turbo timer,550cc injectors,HKS trunk mount IC, B&M s/s,SPEC stg3 6puck clutch, TRD springs. Autometer gauges, PCP reverse indiglo gauges. P/P head,Intake, 17" SSR repl, Kaminari front lip and sides.338whp/272lbs tq at 18psi
FOR SALE! email: [email protected]
http://members.cardomain.com/1quick2
Old 01-23-2004, 06:13 PM
Neutrino's Avatar
Yaya Master
that is 1 Lbs torque per 13.47 Lbs of weight
your 13.47 LBS Tq per 1 pound of weight would result in you having 41757 Lbs torque ...that would be some power
(\__/)
Squealing torque converter Skitzy Express | G Van 4 04-05-2010 02:09 PM
05 tahoe torque converter out. . ??? help bcmagg Tahoe 8 03-22-2010 12:32 PM
Recommendation Wanted: High torque rear end gears SolarDirectCanada Engineering/ Technical 1 10-07-2009 11:13 PM
RPM vs speed vs torque Ris91 Engineering/ Technical 2 07-30-2009 10:14 PM
