Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 03-24-2010, 07:01 PM
Skitzy Skitzy is offline
Squealing torque converter
1998 Chevy Express 1500 Conversion, 5.7L. After the engine warms completely, there is a loud squeal at the area around the torque converter. It is only there at idle, even when moving. It disappears as soon as the accelerator is touched and returns as soon as I take my foot off the pedal. Very embarrassing, especially at traffic lights. Any ideas?
Old 03-25-2010, 09:11 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Squealing torque converter
Pull inspection plate and have a look and see in there.
For anything lose or rubbing.
And be sure to check the end of starter.
MT
Old 04-03-2010, 05:22 PM
I pulled the starter and the inspection plate and I didn't see anything out of order. Nothing rubbing or loose, no metal scratches or shavings. Just what looked like normal shiny flywheel teeth. I tried shimming the starter and that had no effect.
What throws me is that it does not squeal when I press on the gas. It sounds like a bad belt squeal, but I pulled the belt and it's still there. Weird.
I heard that it's possible for the front transmission pump to squeak. Is that true? Or how about a rear main seal or bearing? It is undoubtedly coming from the bell housing area.
Thanks again.
Old 04-04-2010, 09:01 AM
MT-2500's Avatar
AF - Advisor
Thanks again.
I would rule out rear main seal or bearing.
Does it do it in gear or netural?
Hard to say But.
Could be in transmission.
Might be best to get a good repair shop to have a look at it.
Let us know how it goes.
MT
Old 04-05-2010, 01:09 PM
It's squealing in all gears including neutral and park. It only stops when the accelerator is pressed. The pitch is constant, but the frequency is definitely affected by engine speed. AND, it only happens after the engine is fully warmed up, never on cold start up, so heat has something to do with it as well.
A good repair shop sounds like the way to go, when I can afford it. I'll just have to keep pecking at it and getting embarrassed until then.
Thanks
Tags
converter , idle , squeal , torque
