Old 10-07-2009, 07:28 PM
SolarDirectCanada SolarDirectCanada is offline
Recommendation Wanted: High torque rear end gears
I am looking for a reccomendation on a ring and pinion set for a non-automotive application from someone who has worked with a bunch of these. I am using it to orient a solar tracker with the sun. The ring gear would turn less than one revolution a day, forward and then backward but it could be under extreme torque (~2000ft/lbs). It needs to be very reliable and the more gear reduction the better. I would like something that is readily available and a reasonable price. I was thinking maybe something from a larger truck or performance vehicle. Any thoughts. Thanks and sorry for the non-automotive type question.
Old 10-07-2009, 10:13 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Recommendation Wanted: High torque rear end gears
Thread moved to proper venue.
Tags
pinion , reccomendation , ring , torque
