Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-29-2010, 07:57 PM   #1
murphy69mustang
Too much oil
I change oil on a 1991 olds cutlass 2.5 and I put in 1 quart too many. Does anyone think that is enough to put the crank in oil?
murphy69mustang is offline   Reply With Quote
Old 11-29-2010, 07:59 PM   #2
danielsatur
Re: Too much oil
I would drain a quart, because to much oil pressure will cause gaskets to leak.
danielsatur is offline   Reply With Quote
Old 11-29-2010, 08:08 PM   #3
maxwedge
A990 racer
Re: Too much oil
Oil pressure doens't not change by being overfilled, that is a fixed volume system with a pressure relief valve, the issue is windage from the crank can cause the oil to foam up and air bubbles will not lube internal parts, most engines can stand a slight overfill and this will not happen. But to be safe get it down to the proper level.
What are the symptoms of adding too much oil to your car?? Patrix Integra 9 01-17-2011 06:06 PM
Too Much Oil Given in an Oil Change Lois215 General Discussion 1 05-17-2008 05:08 PM
Oil leak, possibly from too much oil? Kearsed Camry/Camry Hybrid/Vista 2 03-13-2007 05:43 PM
too much oil? whitGSR07 Integra 2 02-26-2005 01:38 PM
Will too much oil cause the engine to knock? 92VR4Red Camaro Discussions 3 07-26-2004 05:41 PM
