View Full Version : '71-'87 Civic / CRX
Pages : 1 [2] 3 4 5 6 7 8
  1. Wire tuck things to remove
  2. engine swap 87 civic si help
  3. Need help asap
  4. Keihan carb on 87' civic
  5. Tax Return HELP?
  6. engine mod??
  7. Honda CRX alloy rims
  8. 87' Civic won't start
  9. what happen
  10. fender swap
  11. engine
  12. help me 87 civic SI hatchback body kit?
  13. Electical Issue?
  14. motor swap
  15. 87 civi si Bogs on accelreation, eventually will stall
  16. wheel spacers
  17. how do i remeve the brake rotor???????
  18. smoking when car is still cold
  19. Oooops
  20. Throttle body swaps for 87 si
  21. 83 1500s EM1 head swap
  22. starting up
  23. 87 heads
  24. 85 crx motor swap
  25. Location of the coolant temp sensor and the crank angle sensor
  26. A good little link for christmas from me to you
  27. ZC1(D16A1)Piston question and some other
  28. Firing orders
  29. D15A2 to D16Z6 questions.
  30. Long time no see
  31. 87 civic crx idled funny, now won't start.
  32. engine swap
  33. 87 civic loses power on interstate or going up hill
  34. She idles so rough
  35. hf vs dx/si motors
  36. selling a 4th gen civic
  37. Rover 213SX - 3rd gen Sedan
  38. Cold start unit removal???
  39. 87 CRX battery draining
  40. 83 civic swap
  41. Sponsorship
  42. Hood pully problems
  43. 1987 Honda CRX engine swap
  44. Complete Honda Civic Wagon 1500 engine
  45. clicking?
  46. Instrument panel brake light
  47. 87 CRX quit running
  48. parting CRX
  49. d16a1 integra motor in 85 crx
  50. d15b2 swap into a 87 Si?!
  51. Engine Swap Help!
  52. Heater Core?? Or Thermo??
  53. OT: She said what???
  54. Need D15A2 Head - Quick
  55. i need some info on d16a1
  56. 86 crx hf stalling itself
  57. dual webers vs 3bbl edelbrock
  58. Fuel Pump for 87si Civic HB 1.5L EFI
  59. polyurathane bushings??
  60. 86 HF running hot
  61. 2nd gen fenders
  62. Static Timing for an 83 1500 cc Civic
  63. baseline (static) timing on 84 1.5 liter ?
  64. 87 Civic HB Fuel Tank Removal /Cleaning
  65. 87 si front camber problem
  66. Looking for spare parts for my 87 crx hf
  67. Rip 1983-2005
  68. Front-end Swap
  69. Sunroof problem
  70. 84 CIVIC DX 1.5 eng.
  71. 87si to ZC swap parts list
  72. '84 CRX where are the relays
  73. carb vs fi
  74. Engine swap Civic 86 EW1 to EW3
  75. Sick and tired of missing.
  76. 87crx tranny?
  77. '84 CRX wont turn over help!
  78. crx d15 swap with 93 civic dx
  79. Honda Turboz
  80. 87 crx si alternator removal
  81. motor swap question
  82. 87 crx flashing battery light
  83. off topic, but 1st gen crx related
  84. WTB: 85 CRX Si Distributor
  85. will this tire size fit?
  86. Car wont start, no oil...
  87. Water on the spark plugs...
  88. crx brakes
  89. '86 CRX SI EW4 motor/tranny for sale
  90. Sudden Dying
  91. URGENT: major leak, lots of smoke
  92. coil cracked
  93. ok car guys this is a tough one
  94. 87 Honda Civic Si running problems
  95. junkyard carbs?
  96. 87 crx si budget mods??
  97. how EZ 87SI to sohc ZC swap?
  98. wireing harness
  99. will 87 crx si front shocks bottom out
  100. 78 cvcc wagon motor swap
  101. 86 1.3
  102. What does crx stand for?
  103. crx dx
  104. 84 civic dx - can't get alternator out of engine compartment
  105. rear bumper removal
  106. need help please!
  107. Replacing Battery Cables
  108. FS D16a1 motor parts from 86 integra FS
  109. intermittent wipers
  110. 1986 honda civic, HORRIBLE gas mileage and why?
  111. Wanted: Throttle Position Sensor--86 Civic Si
  112. intake question
  113. getting into the game '87 Honda Civic
  114. 'de-vac' question
  115. 87 crx front suspension?
  116. WTB 87 Honda CRX Lower Dashboard
  117. D15 Bottom D16 Head
  118. are 87 civic bumpers same as crx
  119. d16a1 in a 87 crx turbo question
  120. Sticking throttled position sensor????
  121. new exhaust set-up
  122. b18c5 to 87 RT4WD tranny
  123. In need of a cylinder head 4 a 87 carb'd civic DX..help..!!!!
  124. 87 civic sputters? HELP!
  125. Front fender question...
  126. rad hole
  127. Bent Valve
  128. Sunroof
  129. 87 civic problems
  130. Rad Pepper Racing
  131. Vacuum Hoses
  132. AHH Car wont crank.
  133. Crx Body Kit---help!
  134. need side skirts
  135. engine prob
  136. will a 86 civic dx tranny fit a 87 crx hf?
  137. 87 crx will not start wen hot outside
  138. I hope this isn't one of you!
  139. Pull a Part
  140. 87 CRX SI goodies forsale-ecu, mirrors, etc.
  141. 87 Wont Start.
  142. how can i make a short shifter?
  143. FS:87 crx si shell-integra d16a1
  144. Oil Weight?
  145. interior door panel re-apolstering, How?
  146. Carburetor 1983 Civic 1500
  147. need front shocks from 87 crx
  148. fender situation
  149. 1986 Honda CRX SI Axel Removal
  150. 1986 EICV valve
  151. Lights won't turn off
  152. Lining
  153. 87 CRX Si -- Throttle sticking. HELP!
  154. Will an '85 HF distributor and coil swap into my '85 DX?
  155. E-Brake
  156. Seat Cover Template?
  157. Look at the price
  158. 85-75 power sunroof
  159. New Guy....
  160. Ignitor and coil for '85DX...donor cars?
  161. Installing the serp belt
  162. Project car = confusion
  163. A/C Compressor
  164. 86 crx hf engine swap
  165. ZC Generations
  166. rear drum stuck in 87 crx
  167. crx front
  168. Help me find an engine please !
  169. Changes
  170. fiberglass fenders, nose panel
  171. Wont Start Ran Fine! Help!
  172. Surging but on a Fuel Injected
  173. AaaHhh...(passenger brake)
  174. Compression Test results? Need Help
  175. car problems
  176. Broke Timing Belt
  177. swapping in a d16z6 int 87civic
  178. Odd Brake problem
  179. 84 civic performance websites...
  180. Need info for after market parts 86 Civic Si
  181. Civic Gasket Kits!
  182. 13" Mugen CF-48's
  183. 1986 Honda CRX engine removal
  184. cheapest place to buy oem crx part
  185. How To Tell Car Type
  186. replacement floor pans...
  187. 1st gen crx parts forsale cheap
  188. I need help with Brakes!
  189. 87 crx parts forsale
  190. 85 crx engine
  191. d16a1-zc, d16a1, and d16a8 motors
  192. 86 crx head light switch
  193. transmission problem
  194. Underheating problem
  195. cly head 83
  196. 86 CRX Si Unique Hard Start
  197. H22a in an 87 crx????
  198. 87 crx si 88integra motor swap
  199. civic with issues
  200. cant find anywhere
  201. new to the honda scene
  202. cam shaft torque settings
  203. 1987 crx si want to turbo
  204. Hood opening problem
  205. transmission hondamatic
  206. cat
  207. tappet clearance
  208. 1987 Civic stalls at an idle
  209. removing the OHC Wheel
  210. Best 1/4 mile times?
  211. 85 crx si - side sill metal panels
  212. 87 civic 4wd wagon
  213. DX to Si conversion
  214. Opinions On Purchase
  215. wierd noise from Lfront
  216. fiber glass fenders for 84-87 crx
  217. 87 civic fuel pump question
  218. Miracle Product!
  219. 1987 civic wagon 1.5L dies
  220. 1987 honda civic wagon real time 4 wd
  221. new crx owner
  222. b16?
  223. help suspension/engines
  224. Really bad gas!
  225. proper tire pressure for 87 honda civic si ( 175/70/13)
  226. will a dohc zc fit in my crx si?
  227. Recommended Oil & Oil Filter for 87 Civic SI
  228. wiring an 89 zc
  229. Whats the difference between '87 CRX and '88 CRX
  230. 87 si parts for sale
  231. 87 crx si fuel injectors and fuel rail
  232. parts diagram
  233. wide body kits
  234. ZC in CRX
  235. yes it'i me again the new guy
  236. 86 Civic Radio Replace
  237. 86 Civic Radio Replace
  238. Anyone want an 85 crx?
  239. CRX parts for sale
  240. need parts!!!
  241. driver side window
  242. Go Karts - off topic
  243. What could be causing this??
  244. suspension problems
  245. Car wont idle when it's cold.
  246. A thank you, and a question.
  247. 83 civic hatchback, e' route to fuel pump
  248. dead short or what?
  249. A Honda story...
  250. Low idle, low mental stability
