Our Community is 662,000 Strong. Join Us.
View Full Version : Leganza
  1. What gives Leganza??
  2. injector fuse keeps blowing out
  3. automatic climate control screen is disappearing????help
  4. Power Window Relay
  5. P0342 computer code-mistake??
  6. Do you do this to your leganza?
  7. camshaft sensor location
  8. GPS system for my leganza
  9. daewoo leganza shifting problems in drive!
  10. 2001 Daewoo Leganza problems!
  11. What to do with my Daewoo Leganza?
  12. For Sale: Genuine Daewoo Leganza Plug Wires
  13. Radio wont turn on display. It is now locked
  14. radio code
  15. PLEASE HELP - Lots of Problems
  16. Engine trouble light
  17. Engine trouble scan reader
  18. looking for green relay leganza 2001?
  19. Leganza wont heat up
  20. 2001 Daewoo Laganza cdx for sale
  21. head gasket problem
  22. Looking for legonza answers please?
  23. Leganza alternator swap?
  24. changed head now misses
  25. engine swap on 99 leganza
  26. Daewoo Leganza ABS Warning Light ON
  27. Replacing Leganza Turn Signal
  28. Cant find an oil leak
  29. 2000 Daewoo Leganza Parts for sale
  30. timing marks for 99 daewoo
  31. 2000 Leganza Transmission
  32. CD&Cassette player code
  33. Dose any one know how
  34. Creader codes 1780 and 1781
  35. Hydrogen Daewoo?
  36. cam sensor code
  37. daewoo leganza electric windows
  38. I need to change bulbs on heating control panel daewoo leganza
  39. Jerky 98 Leganza
  40. my emergency brake
  41. Engine Check Lamb
  42. Please Help Serious Problems
  43. Engine Diagram and Problem Starting
  44. Engine Diagram and Problem Starting
  45. Pulling out Relay switches Help?
  46. Leganza 2.0 DOHC Auto Wont start
  47. For Sale: 2000 Leganza Speedometer, 7k mileage
  48. issue with my daewoo
  49. Leganza dash lights
  50. To buy or not to buy - that is the question
  51. Leganza ABS
  52. Leganza Hot/Cold Air
  53. Anyone have an extra pair of lights?
  54. Dome, Trunk and Door Lights not working
  55. Shifting into overdrive
  56. New Leganza owner here....
  57. Heat Problem Solved
  58. Heater problems
  59. where can i find schematics of the leganza engine
  60. Oil light is on and engine knocking
  61. radio code please help
  62. Air con recharged but still not working
  63. Help with cam timing 99 Leganza
  64. speedometer problem
  65. check engine light
  66. Oil pump leaking on 2000 Leganza
  67. Car Dies But Starts Right Back Up?
  68. anyone ever tried this?
  69. anyone had this problem?
  70. brake lights not working... fuse?? pls help
  71. Keyless entry programing
  72. Intermittant POWER button...
  73. No heat problem
  74. 2000 Daewoo Leganza Parts for Sale
  75. Leganza CDX stereo EQ not working
  76. Cold Air Intake
  77. Deawoo leganza trailer hitch
  78. 1999 Daewoo Leganza Need Help
  79. heads up on oil in water 2.2l engine
  80. 2001 daewoo leganza keyless entry
  81. Brake rotors leganza
  82. CD Player Code
  83. Leganza Trailer Hitch For Sale
  84. recharging the a/c system.
  85. Were is fuel filter located?
  86. leganza seems to guzzle to much gas
  87. oil on spark plugs
  88. Camshaft position sensor on Daewoo Lanos
  89. Leganza high pitched sound - brake related
  90. '01 Nubira Camshaft Position Sensor
  91. Jack in the trunk...?
  92. Parts fot Daewoo Leganza 1999
  93. 2000 Daewoo Leganza FOR SALE
  94. Questions about my Daewoo
  95. mods
  96. Leganza parts "to get rid of it"
  97. i want to buy a leganza
  98. cam shaft sensor
  99. 1999 daewoo nubira control arm
  100. HID or Xenon lights for the leganza
  101. Daewoo Camshaft Position Sensor Recall
  102. radio code
  103. looking for A/C for Leganza
  104. Sudden Swearing,,,
  105. leganza shop manual
  106. My check engine light stays on
  107. Gear Shift
  108. Antone have a audio system?
  109. Reason why No fuel? No one can Tell me how .
  110. Fuel pump won't run after engine change.
  111. Camshaft Position Sensor question
  112. Looking for PARTS FOR YOUR DAEWOO???
  113. Do you want Leganza Performance Pulleys
  114. Leganza Sport Ha Hah
  115. blah
  116. about the Lanos
  117. the great leganza
