Our Community is 705,000 Strong. Join Us.
View Full Version : Eclipse Problem Diagnosis
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12
  1. clutch sticking..
  2. idle change after driving for a while
  3. front left wheel wierd movement...
  4. Crazy knock in 3rd, o2 sensor or knock sensor bad?
  5. Question on 1g CAS install
  6. Well finally my warrior 94 eclipse give up on me !!
  7. More throttle related issues
  8. wont idle
  9. Charging problem on 95 Talon
  10. 95 Talon not charging properly
  11. Pocket Logger
  12. Allright now i need some really bad help!!!
  13. My brother's car won't turn over.
  14. smog with a different turbo??
  15. EGR block off plate, now what to do with vacuume lines!!!
  16. i keep burning alt belts....!!!
  17. fuel cut?
  18. New MC and SC prob.
  19. engine help please!!!!!
  20. Check Engine codes.... questions
  21. Poor Gas Mileage....
  22. My A/c Needs To Be Recharged
  23. Please Help Quick!!
  24. I need some help GSX
  25. I have had enough!
  26. car acting weird
  27. question about injector insulators leaking
  28. engine question..
  29. where does this go?
  30. Turbo head
  31. another question for the pros!
  32. starting problem with 1st gen engine into 2nd gen eclipse
  33. starting problem with 1st gen engine into 2nd gen eclipse
  34. how to test isc
  35. Keyless entry problems
  36. Driver side headlight
  37. WOOOO Good gas mileage finally!!
  38. SAFC help
  39. tell me this is lift tick or rod knock or something worse !!
  40. Turn Signals
  41. 98 Eclipse Battery/Alternator Issue
  42. 98 Eclipse Battery/Alternator issue
  43. help please?
  44. Eh, no biggy, but...
  45. Thumping and studdering on Fast Cornering
  46. Help With Transmission
  47. another high idle !!!
  48. AIT Sensor...
  49. no power
  50. Code P0505 problem
  51. 1g auto stuck in gear
  52. Overheating (customer car)
  53. Speedometer sensor location?
  54. Power Transistor Ohm readings
  55. Really Broken motor mount !!! HELP!
  56. OBD port not working. Possible bypass?
  57. blowing smoke
  58. gst electrical problem
  59. Engine Removal
  60. Car down AGAIN!
  61. F*cked Up Idle
  62. Fu*ck*d Up Idle
  63. I think I BROKE my toy ... :(
  64. 93 eclipse and 2nd gear on a 5spd
  65. Sputtering GS
  66. Lifter tick question...
  67. 6-bolt down
  68. bent valves? or timing way off?
  69. Random Misfires after new injector/ecu install
  70. If its not one thing its another....
  71. 92 Laser with Trany problems?
  72. Timing emergency
  73. new problem.. power steering?
  74. Im Lost
  75. 91 talon overheating dont know y
  76. Damn EGR!!
  77. 96 Eclipse with a Problem
  78. Someone help me
  79. eclipse RS 98 don't spark wont start
  80. Silent/Balance Shaft
  81. New problem... Clutch, maybe?
  82. Broken Door Handle Again
  83. Timing Belt problem - engine stopped turning
  84. hesitating starts, stumbles before warm
  85. dsm clutch problems
  86. Low oil pressure
  87. Idle problem
  88. Error 505
  89. 2001 Spyder convertible top won't open
  90. Front Axle Help Please
  91. Timing Belts
  92. 1998 Spyder Tranny
  93. Antifreeze hoses
  94. help again
  95. Transmission 1g to 2g- IMPORTANT
  96. Why I hate my silencer...
  97. fans wont work
  98. Wipers!!!!!
  99. (4 Eagle talon Died and now won't start help!!
  100. my poor car
  101. Tick Tick Tick Tick Problem Help
  102. fuel pump??
  103. breaks issue? squeek
  104. Spun bearing?
  105. car stalls after runnin for about an hour
  106. Every summer this happens!
  107. Guage Problem Bah!!!!
  108. Van suddenly died on the road
  109. no spark
  110. front left blinker light out
  111. stumbling engine
  112. Rusted/Cracked Strut Tower
  113. clutch problem??
  114. borrrrrrrrringggggggg
  115. Consequences of breaking abalance shaft belt???
  116. No Spark on 1 and 4?!?! Need Help ASAP!
  117. crank case presser
  118. Head Gasket or rings?
  119. Noooooooo!!!!!!!!!!!!!!!!
  120. Transmisson problem
  121. Winding noise...
  122. Quick Valve Gasket and Cover Replacement question...
  123. HELP! Oil in coolant overflow AGAIN!
  124. Transfer case binding? why?
  125. Someone Please Help I am ready to shoot something
  126. High Oil Pressure
  127. Banjo bolt break on Head.
  128. tapping noise ??
  129. Got problems with GSX just put on the road.... suggestions plz
  130. head bolt torque
  131. 4g64 difference?
  132. oil loss
  133. oil in air filter.
  134. Grrinnddd Zgsgzgzgz
  135. automotive code reader
  136. can't keep oil in the car!!
  137. I'm about to kill some(one)thing
  138. how to adjust tps
  139. My beater is having problems?
  140. IAT Sensor: High Current
  141. Alignment question
  142. start problem
  143. burning too much oil
  144. hole in the fire wall
  145. problems apon problems
  146. Turbo...Shaft Play
  147. fuel filter questions
  148. need help
  149. Coolant and hesitation problem HELP!!
  150. looking for bottom end...
  151. need help with a 91gsx
  152. Still removing valves...
  153. Code 14
  154. 95 won,t run.
  155. a/c and radio no power
  156. Possible transfer case leak
  157. Installed turbo timer now alarm doesnt work
  158. please help! 97 gst
  159. My baby has died and I don't know why..
  160. Runs bad after 4000RPM
  161. Help my key wont turn !!!
  162. wastegate help
  163. Alt Belt Torn up...
  164. Alt tensioner on a/t 1g.
  165. vacuum lines and high idle
  166. 1999 Spyer.....ticking In Engine Which Does With Rpm?
  167. Oil Change For 1999 Spyder?????
  168. Need Help immediately!!
  169. Car running like shit and running rich
  170. car wont start
  171. Possible boost leak....please help
  172. Turbo Diagnostic
  173. Ok now its a new problem
  174. runing rich for some reason
  175. wheel locks up?
  176. 1g' sunroofs
  177. big problem and I need help
  178. Car Dies overnight... please help
  179. My car is finally starting to show it'd DSM side.
  180. Transmission problem???
  181. wont start after timing belt replacement
  182. 95 eclipse sunroof is stuck open. Please Help
  183. Help...Soon as possible :(
  184. Revert problem !!
  185. got codes need help!
  186. Tranny Question...
  187. suspension help PLEASE
  188. oil in wrong spot
  189. No idle after battery replacement
  190. GReddy rs leaking? how to tune?
  191. Engine Viberating more than normal
  192. Worried about going to far into the HEAD
  193. Can Anyone Help?
  194. exhaust problem
  195. 4 things one problem?
  196. Turn Signal Stays On!!! Help!!!!!!
  197. Fan trouble
  198. Check Engine Codes
  199. 2000 Mitsubishi Eclipse-turn Signal Stays On!
  200. exhaust problems
  201. Bouncy Bouncy Bounce!!!!!!!!!
  202. NOOO way to get locking lug off!!!
  203. Help with this code please
  204. lil help
  205. idle issues with 1g
  206. 95 Talon dangerous suspension problem? Need Help!
  207. BAD SHIFTING...new clutch or tranny problem?
  208. Smoke coming from the exhaust and no boost pressure
  209. tranny gets stuck in gear until restart
  210. bad gas mileage
  211. vacuum diagram for 95 eclipse
  212. fuel pressure regulator...
  213. crank pully issues
  214. weird tranny problem
  215. Weird Problems.....
  216. What wrong with my fift gear ??
  217. poly urethane blitz bumper probs
  218. no oil pressure wtf?
  219. I think I blew my head gasket...
  220. Gas gauge is a little inaccurate....
  221. Siezed Balance Shaft
  222. Hello!/Halfshaft problem.
  223. Sick of it!
  224. buzzing sound when i start my car!!
  225. running rich
  226. no heat!!!!!!!!
  227. 4g64 HEADER PROBS!
  228. new thermostat mabybe ??
  229. Noise comming from transmission
  230. dropped Fuel Pressure?
  231. 91 GSX help
  232. My RPM Stayed At 3000????
  233. 1 plug on the tranny ??
  234. tranny
  235. fuel pump problem?
  236. 94 eagle talon es wont start please help!!!
  237. bad oil leak
  238. Loud knocking, whats going on?
  239. No oil pressure
  240. Head is Knocking
  241. please help!!my brain exploded
  242. YAY I got my DSM and its overheating! ....
  243. lots of smoke
  244. cams
  245. Broken Door Handle
  246. Car only starts when it wants, and dies after 4k RPM.
  247. grinding sound on engine
  248. No start/start/high emmisions/bad idle.... lol 92 non turbo
  249. Raido Code and Power antenna
  250. eclipse bad rpm
