Lifter tick question...
NateS
05-28-2006, 06:26 PM
Okay so like any other dsm with more than 80k miles on the motor my car has lifter tick. It used to be every once in awhile like when I would come to a stop for awhile but, it would go away while I started driving. I changed my oil(full synthetic) yesterday and went out last night and I noticed it was getting horribly worse. It not only was REALLY loud when I came to a stop but, it also made the noise while I was driving. The clicking noise sounds like a piece of cardboard(playing card) in a fan or bike wheel. I noticed if I let it sit idle for a few minutes or shut the car off and let it cool down then start it up the sound goes away for awhile then comes back. Is this still lifter tick or could this be something horribly worse? I remember someone saying something about a bad rod bearing causing a similiar noise. Any help is much appreciated. Thanks.
gthompson97
05-28-2006, 06:46 PM
A bad rod bearing will cause a similiar sounding noise, but on a MUCH MUCH worse scale and the more you drive the car the louder and louder it will get. A quick check to make sure it's not your rod bearings is to pull off the oil pan and the rod caps and then inspect the bearing (inside and outside) for any wearing, scarring, or grooves. If all 4 of them turn out to be in good condition, then your problem still is lifter tick. You could install a set of 3rd gen revised lifters and lifter tick will be no more.
Killa
05-28-2006, 08:00 PM
do you know what lift tick sound like ?? I can send you the clip of the sound. I been send to alot people around the net LOL . AIM Hoangde972
NateS
05-28-2006, 10:29 PM
Yeah I know what lifter tick sounds like. My car has had a minor case of lifter tick for awhile now.
Anyway, today my car wasn't making the noise, just a quiet lifter tick. So, I took my car out again and it is just like it was before, just a minor case of lifter tick that goes away when I pull the oil pressure up a bit or start driving. So, I am almost positive that the noise was just some nasty lifter tick. Could changing your oil temporarily make your lifter tick worse? It got loud right after I put some fresh full synthetic in her.
I have thought about putting some 3rd gen lifters in it but, I would rather put my money into something else for now. Thanks for the input everyone.
Killa
05-28-2006, 11:01 PM
yes ! it good to let the oil get old little bit, fully syntec oil is design for that, I change my oil every 3k mile or 2.5k mile. not every 3 month.
NateS
05-28-2006, 11:26 PM
Yeah, I ussually change my oil and filter every 3k miles.
gthompson97
05-29-2006, 02:35 AM
Changing to fully synthetic could cause a louder lifter tick because it cleans up "buildup" in your engine and could make tolerances a little bigger, therefore causing a little bit worse lifter tick.
SySt3mR00t
06-06-2006, 01:15 AM
i want to go 3g lifters... can i jus buy oem 3g lifters .. and put them in my 2g ... or are they modified somehow >???
nova1313
06-06-2006, 06:52 AM
there misnamed. they are from a 2g just the later dates of them 99's only i think. They aren't from a 3g that i know of.
So no no modification needed.
