Mitsubishi
Eclipse/Talon/Laser
> Engine, Transmission and Drivetrain
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
Afew things to go over before i start my car for the 1st time!!!
Throttle body coolant bypass to turbo?
How does this 2.3 stroker look?
Coolingmist H20 install... Pump failure..
what do you think?
Evo 3 16g Questions
1g cat ?'s
Will an engine from an 95 automatic work in a 5 spd non turbo?
J-Pipe!!!!
Injector Install help
after market fuel filters
preparing for the future
20g or t3/t4 ?
Remote mount turbo setup please help
What Turbo for this 420a setup?
Spun Bearings in Balance Shaft
Low profiles or slicks?
smog issues..
Exhaust Cutout
Transmissions
making a 7 bolt last...
Brake rotor Wearver V.S Valucraft
The GSX got owned today
1g Fwd turbo & n/t trannys
1g Eprom Ecu's
6 bolt vs. 7 bolt build...help!
bent valves
Brembo big brake kit
Bad new !!
Crazy cool kinda awesome Idea...
Boost leak test... results
Good news, bad news for the FMIC LOOK AT ME!
I have a few questions that need to be answered plz!!!
Turbo 2.4: Part 2 - 450 injector swap w/resistor pack~pics
Hedman Headers
A few link questions
Blow off valve
New brake pads for Thor
what do you guys think of this setup
valve replacement
tranny swap
bye bye to the gst:(
Axles
let me know
rebuilding head
heat problem
installing 650cc injectors...questions
1g GS
Turbos?
open turbo(no intake tube/cone)
Injector preference
Cant get over 9psi of boost
Injectors and link
AWD conversion....whats involved...
I know nothing about Turbo's
Serious RS-T Question....
CrankShaft Position Sensor
DSM experts! How can I get more Horse power?
Holy boost leak batman!
Can't control boost
1997 eagle talon part out
Turbo 2.4L: Part one: Lots of parts and lots of pics
Mystery Turbo Strikes again!
What fluid in my tranny?
Alittle Tuning. Questions (of course)
killing clutter
We have: fuel, compression, timing, and spark. We dont have a running car. HELP!
proper clutch adjustment
exhaust
Awesome BCS/MBC mod
Asking about a turbo now for the future!!
Yay porting! Carbide burs, which one(s)?
looky at the FMIC
Eprom
HPDE - Willow Springs Track Event - June 3rd Horsethief Mile
gst air filter and adapter on a 2.4l 4g64
Opinions on IC piping
2g brakes
Maxing out my turbo....question
Flywheel
Psi
Spring Install
Need help with tire sizing
Now I am flat out confused.
Oil Return line gasket.
Im not sure about this bellhousing hole :(
Best Oil?
Does this turbo sound good?
FP2's or DKS's, opinions please!
S-afc Ii
S-afc Ii
what size injectors do i get??
Dsmlink Help!!!
conversions
Stroke a motor 2.3 or 2.4
Shitty gas mileage
stupid question
INJEN Short Ram Intake question
Who's Knocking ...?
Ford 7.3l Powerstroke Turbo on a DSM
ECU Question
Raisimg compression on 420a
Stock turbo PSi
Reduce weight transfer?
Intercooler sprayer, worth it?
FOR SALE- Transfer case- REAL CHEAP good condition
Which LSD?
3000 gt motor
95 awd trans/transfer case question??
And you guys thought kevins turbo was big...
B&M fuel pressure regulator
95 Talon ESI
Oil Pan Gasket ... To be? or Not to be? That is the question!
big 16g
air intake for 2.4l spyder
Jet Engine
Help !!! attempting to build 4g64T/ Tranny???
Question about injectors and turbos...
digital DIS-2 questuions
HELP!!! Turbo setup decision
C2 guage... just bought
head differences
Several Brake Questions?
dual exhaust..
DSMlink
pros and cons about 2g pistons
Turbo ECU in Non-Turbo
How do i stroke it?
Damn this sucks!!!!
Front Oxygen Location On a 2.4 Engine?
Another TB question. New ? tho
450's and me...
Garrett GT35R info please!!!!
Short shifter/bushings review
1g gs w/ 2.0-putting a turbo on,
size of fmic?
Mixing oil grades ok?
Tanabe coilovers??
4G63 Proper Break In
4g63 cams fit 420a?
What epoxy to use on motor mounts?
cams, Cams, CAms, CAMs, CAMS!!!!!!
Intricate Knowlege of 16g needed
420a engine options
Engine build options... opinions please
4g63 or 4g63t
96 RS drum to disc conversion tut
Torque specs
RS/GS Turbo Exhaust Question
Just got the my new turbo.
Intercooler size question
clutch problem
fuel pumps?
Stroker Kit Driving Me Crazy !!!!
Vacuum Lines
what do you think
Tires... cheap and sticky... suggestions?
2g head on a 6bolt block?
Which is better BG sycroshift II or Redline Heavy duty gear oil?!?!
Does this happen to you?
whats wrong with my fuel system?
cold air intake
Question about N/T and ICs...
Tb boring ?
axel mileage life?
Ahhhhhhh sweeeet silence!!
This 1g Head and intake swap sucks!!! Need some help again
Gasket set from felpro
UDP ( ebay )
Ebay Intercooler Kit
Intercooler flow rates
mega squirt vs. Safc-II
Intercooler and Front Crankshaft Seal question
Nitrous... help!
Transmission SWAP...
can someone answer my question
knock
Timing belt tension
Insane Mod List!!!!!
4g93t motor swap into a 1990 eagle talon
need help with a 91 gsx
cam gear ?
mega squirt for 4g63 motor
Need to find good price on FMIC piping
DSMLINK vs. APEXi Super AFC II
Swapin full turbo kits
Turbo exchange list
Bunny hop won't stop!
Oil pump swap/balance shaft kit?
What to do
need FMIC piping
just curious...drag ?s
Used cams.... do it or no?
msd box
95 Road Racing Spec Gsx
O2 sensors
Shifter questions
Opinions please..
Cylinder Head
Gear Oil (?) or tranny fluid?
Worked on my car today part 3
Couple of ¿'s any answers very appreciated
New Rod/Piston combo.... motor is ripped down to block!
Here's the setup I'm going with... What's missing?
I bought an air/fuel gauge. Got a question.
More boom for my buck...anyone?
My friend Mike's Talon setup plans.... opinions please!
s-afc2 question
fuel additives
4g63t 1g swap
Slow boy racing limited slip differential (LSD)
Bastard 20g is it overkill on my fwd
What to buy?
Need to take drastic measures
oil pressure
looky looky what I am getting
Rotor installation
Fuel Filter Question
2.7? Anyone know anything?
finally decided what motor I want
how to install cool air intake on 97 GS SPYDER ECLIPSE
hey clipsekid
420a upgrades....know of any?
A question on exhaust if I may
who made mitsubishi oil filter ??
black or green injectors
6 Bolt vs 7 Bolt
Starion FMIC OR?
Pilot Bearing on a Eclipse??
Fluids and modding (2 questions)
MY PREVIOUS bouncy bounce post
engine SWAP
rear rotors
Megan racing lowering springs
What do you guys thinks about these?
Sway Bars
2g pistons/1g rods questions
A little survey if I may...
16G or t28
My first engine mod
FP T25/28 17 psi actuator
about the 1g cam sensor?
pulley(s)
6 Bolt motors
turbo upgrade
420a Valve Job Guide???
Help w t3/t4 install.
Dammit stuck again!!!
95 eagle talon FWD Suspension
