Mitsubishi
Eclipse/Talon/Laser
> Engine, Transmission and Drivetrain
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
turbo
GSX project
I am back, kinda
pacesetter exhausts
2.0n/t tranny in 1.8l DSM
Which Belt?
SAFC installtion
Evo III 16G with 20G compressor wheel
Found a turbo for sale...
new turbo/intercooler setup
need ideas....
Need to crush my 1g bov
Engine swap quick question
Best stuff for all motor
:: HELP :: Removing an ALternator
Oil Coolers
Timing....? Ask For Help !!!!
FMIC pics after Install!!!!
Fuel Systems: Stock turbo and N/T
I need a wiring diagram for a SAFC 2 in a 2g GST
Rear o2 install + PICS
I Hate Fedex
Couldn't believe what a difference an intake made for my GT!
Engine swap in '95 Talon TSI AWD
1995 mitsubishi eclipse gsx
4G63 Head break in
Question about tubular o2 housing
Does boost stay constant till redline?
Computer effect car mileage?
60k mi. Timing Belt cost
Head is DONE...almost
Buschur Downpipe
New Setup
How to make and do...
I want new 3rd
Dropped my head off today to be built...
420A turbokit
G-Tech performance meter
Alright, this seems a bit too good to be true..
Spark Plug Wire Diagram 1994 Mitsubishi Eclipse 1.8
Fuel Pump rewire for 2g awd
Ebay intake tubes
Engine Blew
95 tsi center crossmember
Knock Sensor
running lean and rich!!
1st gen turbo
ECU and Tuning ?
turbo question please help
Some purchases on impulse
550cc injectors?
I think I'm buying cams.. Finally
turbo questions
Rebuild material opinions
1" lower
How well do 2G internals hold up?
Flames
exhaust??
6 bolt engine swap
Engine "VIN" question
14b to 16g
Ksports coilover for daily driving?
Where is the IAT sensor?
1g head on a 2g
What will ruin your clutch? Help
420a
max boost?
Coil on plug setup
huge problem
Trans fluid
trans swap and performance mods
turbo options
bypass emission seloniods?
Battery relocation
oil feed line
What kind of clutch?
Prothane Motor Mount Install
Motor or Tranny help
420a engine
2001 PT Cruiser Control Arm Bushings
need cheap performance tips
14b V.S big 16g turbo
Suspension question???
ok Ready to hit the swap
Clutch removal instructions
Need help with removing stock manifold
Increases MPG and Performance?
wheel hop?
My ACT2600 gone
I'm Building a 6 bolt 4G64 for the Spyder. Some questions.
New Project Car!... Need Engine Info
a backyards idea
boost gauge and boost controller problem!
Is a stage 3 head a good idea?
Upgrading Fuel system... opinions
japanese evo3 --> 98 gs-t 4g63
fuel cells
True AWD?
brake pads?
Maf removeal question
Dumb n00b Question; Suspension/Shocks
What FPR to go with?
Choosing nitrous systems....help
dsm chips
Rockers and Lifters...
transmission type???
short ram intake help
so whats a studderbox
My problem must be clucth slippage...
need your help to estimate hp/tq for 1g.
Max boost on stock bottom end
TRE or Shep Tranny
Clutch decision
Question about crankwalk?
Engine Swap
New intake and throttle body help!
I like smaller wheels, maybe?
What turbo is better?
v trim?? from SBR
MLS vs Copper head gasket
1.8 liter stroker
Transmission... '90 in a '91 (I b/l)
T28 w/ tub. manifold vs. hahn super 16G
which turbo is this?
has anyone tryed these pistons?
Exedy Stage 2 vs. ACT 2100
i know its been a while (pics)
Is lsd any good?
50-trim...
upping a 98 eclipse... need assistance plz
ehh screw the evo 3 16g?
Upgrading Turbo
Knock off short throw shifter?
Upgrades for 4g63t
spark plugs and wires
2G head on 4g63t
New turbo
Dual Piston upgrade ;)
Weird turn of events
Intake Mani port
4g63 heads on a 4g37
1 more quick question!
Oversized Valve guides??? HELP
would you buy this?
iac location`
Intercooler sizing
Rebuilding the Spyder's 7 bolt
Axles...
GST converted to GSX
vehicle comparison ford lightning vs eclipse turbo
injectors?
16g install gone Wrong.
Setup Questions
1G BOV in stock 2G
1991 plymouth laser 1.8 litre engine. is it interference motor?
Megan Racing
Non-turbo turboed track time
Finalizing Head please help...
when should i shift?
Collective: How to break-in your engine thread
50 in my Tsi
Question about fuel injectors now...
14b oil drain
Punishment racing dp or Ebay dp?
Left Motor Mount Replacement on 2.4 Spyder?
Flywheel
wonting to turbo
ARP's...
Winter/spring plans and my future setup... comments wanted
Stock Oil Cooler
Striping my car
new air filter
ok i dont know much
Suspension
? on my tuning set up?
Help with wheel bearings
The truth please
$2000 budget for 2007
How do u feel about this
Advancing the timing
eclipse gts vs grand prix gtp
420a
50 trim setup!!!
How do I figure what fuel pressure to run?
Turbo Axles
the big and the small
cams and head
GM 3.3 bar sensor?
Stainless Fuel Lines...
Turbo Questions
Stock intake vs. cyclone
Chrysler 4g63 and Mitsu 4g63 WTF???
Drag Strip
Going to a 90 N/T throttle body question
what kinda motor can u drop in a talon esi
Axles
performance help
what injectors for t28
Eliminating EGR ???
Mivec
idle problem
bought a clutch to install
Machine shop for block prep
Favorite feature of DSMLink
94 laser with Hyundai 4g63?
More Problems (breaks)
Will this fit?
HKS SSQV bov question
Wiring AFC to monitor knock
1st gen turbo
1st gen 4g63 swap ???
How to keep up performance
Need sum help
Ignition problem?
bov sound
t3 turbo ?'s
Excellent on-line tire size calculator
High-flow fuel filter...
Bearing clearances
Fixed CAI
how to tune the bov
Brake lines
what rods in what cyl's?
Engine swap
Ebay Fmic ?
fuel cut question
I fixed my turbo problem...just one last kink to figure out!!!!
Loud air sound
Tuning...
porting a turbo
16g turob im 1g eclipse
INSTALLING a t3/t4 turbo on my eclipse
talon doin 9 seconds in a 1/4?
clutch ?
96GsX, intake and exhaust question
Do I need ARP and Cometic?
$9,000....on a 2gnt, what to do....?
Holy sh*t O2 housing GONE??
Head Question
boost controller help
JE 9:1 pistons and headgasket choice
turbo / stroker
New recall info for 1997/98 Eagle Talons
installing a 6 bolt in a 2g
clutch slave cylinder..
stroker motors
?'s about new exhaust mani
Valve Cover Question
Oil Catch tank
