Mitsubishi
Eclipse/Talon/Laser
> Engine, Transmission and Drivetrain
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
NEX coilovers. Quality? Will they fit on my Spyder?
Which engine oil is best?
Pick My FMIC for Me!
tranny
Why more boost?
headers for sale
1g bov
Installing polyurethane motor mounts.
1G to 2G swap
Gear Ratios...
16g turbo
Best Sounding Exhaust
Let's talk about brakes.......
Exhaust Silencer- Inspection issues?
ESi performance products
Bov
Something about Turbo..?
Sup'in up a GS..is it worth it?
Injector time :D
turbo charge a gs eclipse--- and trans prob
Hahn Turbocharger
question about a t25 turbo
Exhaust
Question about my new palm m105
Intake Manifold
Blittz Super Sound
92 eclipse gs
Big turbo
Data Logging Software
boost controller
Tranny Swap / Exchange
Performance levels/money
Ignition System
What kind of power could I expect if I....
Top 3 Differentials?
Stock Tranny Question
First Logs w/ Evo16g
Cryo2
2G engine/ performance
Turbo question
Can someone check out my logs?
Relocating MAF
Engine Potential?
T25 Wastegate
Air Intake for a 1G NT?
Newbie in need of help.
Relatively new...to me neways
what size/kind intake?
Nology HotWires!
Magnaflow Exhaust - need to pick freebie
is this a good deal??
exhaust question
1.8l 4g37nt
Best time to hit the track...
Anyone heard of Turbonator?
got an idea
What are the parts needed to do the evo III turbo swap??
battery question
To go supra IC or trade in for 14B?
stock smic
RULES & REGULATIONS On This Forum!!!
eclipse spyder vs gmc sierra v8
which fuel pump 190lph or 255lph???
My 98 Gsx and a GT2871R is it possible?
NEW Parts today....
Power pulleys
2g or 3g HELP DESCISION
Newbie!!
The 1ooth time ya'll have heard this!
milled head too much ?
turbo acting up
Eclipse!!!
help plz
turbo specs...
please don't hate me
Cam Gears
1g or 2g throttle
96' gs engone swap
Newish Greddy type-RS BOV
Turboing my 96 with 104000 miles
intake for n/t spyder
cheap turbo
Those w/boostguages....
TPR performance parts
Turbo Question
97 eclipse rs worth it?
crushed 1g bov with low boost?
Boost and Milage
Ignition Coil Connector
boost controller?
s-afc I tunning/help!
NEW THROTTLE BODY & COILPACK
Gsx Bov
whitch way should i go?....
Shattering Clutches?!?
95 eclipse intake.
cyclone intake
Tranny swap from 2.0 auto to 1.8 manual
91 6 bolt timing cycle??
120,000 miles
stupid questions
my towns full of rice...
turboing a 420a
aftermarket headers after turboing a n/t?
99gs into 99rs swap-Help!
cat back exhaust questions
4g63 Swap
FS: 2G eclipse pillar dual guage pod
Now EvoIII 16g Powered! (56k warn)
GSX engine
Greddy Exhaust
Ecu
check all maintenance before modding!!
automatic worth modding?
gsx twin turbo
What type of header are these?
evo swap in a 91 GSX
Looking for crankshaft??
biger filter=more pover?
best brand of headers?
Specs?
looking for cheap 2ngen gsx under 75kmiles under $10000
03 wrx impreza
new here
embarassing turbo lag.. loss to honda
engine for sale
need help installing a mbc on my 2g t25
BOV problems
Really stumped, need advice.
Looking For A Eclipse Gs-t!!!
a couple questions about strut tower braces
90' Eagle TSI, 99' "dodge" Avenger (mitsu), the Avenger is purdy, but has no guts
trying to hit the 550-600hp mark in my 90' eclipse turbo... help.
A SPYderrrrr
New to the board
wheels and tires
Wish Me Luck Guys.
n1 exhaust
engine burning oil
Flywheel choices???
Anyone know where the butterfly control is on the cyclone intake?
how to raise a coilover suspension? need a swayer tool?
another fun night at the races
96 TSi and 1g intake manifold
GST Hardtop or drop top?
What does this Do???
Balance shaft on a 3G
awd question
Great Piece of Info
Question about 1g/2g turbo engine
Needs to hanle le mans style...
These are the parts need...
HEMI Engines
exhaust
Sorry if its stupid, but I need help.
How does this sound for mods?
Cylinder Sleeving Kits???
Damn My Palm
shorter intake manifold runners?
How much boost???
Eclipse GSX vs Supra twin turbo
Gsx
Pros and Cons on lowering C/R in 4g63-T
eclipse 90-96
Any Advice On First Mod To Stock 97 Eclipse Gs
quarter mile times for 1st gen turbo fwd dsms?
External WG Question
Deck Surface Machining
Set up Options....
My T25 creeping? =O
4G63 compression?
4g63 problems
Got a Chance to Buy a Local EvoIII
advise on bushings ..Energy Suspension?
Does anyone know what the speed limiter (governor) is set at on a 98 eclipse gs?
egr block off plate
turbo question
Timing discussion.
Help for a rookie please!!!!!
Best turbo.....bov?
Kyb AGX's
Tein S. Tech Question
The Mis-Firing System? Help?
02 dump?
suspension help
boost??
what bennifits will a venom fuelrail? give me?
main bolts & bearing question
Max Speed Tranny can go
what's involved in rebuilding a turbo??
Too little Voltage on Aftermarket Fuel Pump?
maxing out an eclipse
block re-done with topline pistons.
Is there any way to make it so you can safely shift in an automatic without...
what size fuel pump?
97 GS ... What to increase HP
clutch info
engines
what do you think about this stoker kit.
Harness Bar ??
Shaving the fly wheel?
2g throttle body
any pros out there? i need help
Max Boost
evo engine swap
Engine Swap 2.0
Best Suspension Kit for GSX?
Intake question...
Power Shuts Off Then Turns Back On
cold air intakes? Really?
crankshaft question
evo VIII engine in a 95 eclipse
Flywheel
www.ststurbo.com
clutch pedal!!!
Deck height and blown motors.
is a te04h decent turbo?
need info for a gs engine swap, please!
Reliability: talon vs eclipse
piston ring blow by on 95 gst
98 Spyder GS, Where to start?
cyclone itm
how do take off the speed limiter on a 1.8 ecu
posible fuel cut??
Can overdrive be utilized in any way during a race?
talon 93 es
Cruise Control Switch
will evo turbo work?
need help with my sandwhich adapter.
boost controller
Plans Have Changed...
how much power est
Apex I Air Ruel Controller
96 eclipse suspension.
8 valve???
I Need Help!! (96 Mitsubishi Eclipse)
At what RPM should I launch my stock GST at the track?
transmission problem
need help about boostin my eclipse
My first upgrade to a stock GST should be...
anyone know of a good 2g eclipse forum?
Rumors?
95 rs stock specifications
Crankwalk on 97
turbonator?
help!~! can i fit a gst engine to a regular gs?
is boring over/stroking really a practical mod?
How do i get my car to.....
1.8L to a 2.0L engine swap
4g63 transmission
