Mitsubishi
Eclipse/Talon/Laser
> Engine, Transmission and Drivetrain
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
turbine housing options
Yonaka Exhaust??
Rims
breather filters?
I Want To Rev Up To 9000 Or More
What is this????
greddy type rs bov on a 1g
...Mufflers...
What boost controler?
Show now go.!!!!!!
Exhaust wrap-- how effective?
EVO III Exhaust Manifold
turbo upgrade
question!
Center Diff
97 AWD Tranny on a 95 AWD???
3" Downpipe
What suspention set up?
Zeitronix wideband O2
Stock 2g engine upgrades...
i just got a turbo for my 94 talon
FedEx dropped this off today..
¿Intercooler?
Garrett T-28 bolt on upgrade Turbo
Just Installed 190lph...AFC adjustments?
I bought a 97 GSX... already modded
Wideband O2 Sensor.
91 eclipse clutch
From 13 to 18 PSI With a 1G BOV
Upgrades~!?~
Eclipse AWD Tranny For Sale
need info an turboing a 95 talon esi
Boost control solinoid
boost pressure
Turbo upgrade...
95 Eclipse Clutch?
New Turbo
FMIC Choice, Need Advice!
Motor Time
NEED A RS engine
Head Gasket
Boost gauge?
Boost gauge?
suggestions on what to buy
Injectors...
fuel reg.
opinions on headers
Intake Question
gst to gsx conversion
Strut Tower Bars Please Help!!!!!!!!!
Removing turbine housing while on car or not?
What now???
Fuel injectors for a supercharged 420A
99 spyder GS Intake modification
engine problems
just making sure guys...
2000 eclipse gt swap
Does a neon's 420A head fit an Eclipse
Finally a new turbo
"check engine" light..not good
from stock...to rocket!
skunk2 exhaust
turbo's
Trade in Value
Time for my mods, new turbo, front mount, manifold...everything.need opinions
ATX or MTX
Best Suspension?
Eclipse RS Motor/Tranny Swap With Evo 6
Sharing suspension info
Boring out engine
Boring out engine
TD05-16G TURBO - 93 Eagle Talon AWD TSI
no boost!!!
problems with eclipse fire trowing
Graduation present and suggestions..
what is MIVEC???
reassurance on purchase
Help me pick my suspension plz
new bolt on turbos for 1g dsm
head stuff - cams, etc.
fitting an 1G bov on 2G car
Regular Unleaded
Stock Injectors?
heeeelp! maft setting problems
Apexi Power intake filter
[B]Engine Swap[/B]
downpipe/cat question
O2 Dump tube
installing an underpulley
Phantom Grip LSD and cornering
remove cat and resonators ?
3" o2 eliminator Downpipe with internal or external dump
1g manual tranny swap to 2g 7blt engine
eclipse piston????
building a rs
need help
GM MAFt and venting the type-S. Exact setup and install procedure?
Yup, another turboing an N/A Q...
STOCK intercooler piping...
Cheap exhaust is hard to find
Turbo Cams on NA Engine?!
turboing a GS with GST parts
O2 Eliminator
Max Horespower for stock axles?????
water injection
Best Sounding Muffler for Eclipse RS
turboing a GS
Stock 4g63t
Mach V's new A/F tuning setup VS Apexi AFC-R
whats a DSM?
Manual boost controller
cheap upgrades?
bleed clutch
What makes it as good as it is?
14b installed, but doest feel that strong.
High Flow Cat and Back Pressure
GS Exhaust on a GS-T?
Intakes...which one?
wideband
Clutch help
clutch pedal low
Ignition Switch
Engine Rebuild ?'s 90' talon tsi
4g63 engine and trany swap
pocket logger??
Reducing drivetrain loses
narrow band a/f gauge
Catback
Motor Swap
cleaning head lights
cheap upgrades
what to do next?
automatic trans to manual..... can it be done easily????
20g or evo 16g
Ecu Upgrade
different block?
Electric Supercharger?
Hayame coilovers? Anybody know 'em? Check out the spring rates
Turbo question
which clutch?
Looking for a performance intake manifold for a 92 1.8
2.25'' exhaust too small?
motor winding?
Stock to Performance Intake Upgrade
Can my 420A fit into a Neon?
lower compression ratio?
GFB Stealth FX Dual Port Blow off Valve
safc2
Brakes and rotors
What lights are these?
Megan Racing??
EVO VIII Intercooler piping
What is the best turbo upgrade for my 95 Talon TSi?
pocket logger??
255lph fuel pump
Throttle body help
Remove the cat or hightflow cat ?
Whose High Flow Cat?
whats a good turbo?
Shortblock & head/longblock
t3 t4 housing
budget dsming. Cheapest bang for the buck
safc2 help!!!
exhaust question
FS: 1996 Eagle Talon TSI 51K
Best CatBack exhaust GSX99
I Need help with my RS!!!
horrible knock
Thrust Bearings
Eclipse GSX 99 Cold air intake
Stock BOV
lacking boost
Engine Swap Help Me!!!!!!
Supercharged 420A? Does this kit work?!
My 14b I just got! Crack in exhaust flapper
(1) What boost to run on new turbo? (2) Boost spike question
Rebuild 420A
Spyder 2.0L Turbo
Weird Noise!?!?!
engine swap
Launching the car
Fuel Pressure Adjustments
Car dieing after Installs
cold air intake
how many pulleys are in an eclipse?
need help with cams.
is there any way to make ur gst spyder faster with out buying any parts?
engines
I Need Some Help!!!!!!!!!Suggestion Please
How you like the Eclipse?
More HP!!!
AutoCross
1g engine in to 2g
20HP for 30 dollars!?!?! No its not the turbonator
Trying to build the perfect 420A head for a turbo
Twin Turbo
attaining 270awhp on a 14b ?
ACT prolite or streetlite flywheels
Need help with suspension
any ideas and opnions??
Question For Hardcore DSM Tuners...
noob question about dsm turbos
420a Awd
2G Eclipse RS -- What do I need to support 500+HP?
Shop manual
Cltuch help
clutch slave cylinder
fmic hp gains
turbo charger question
ITB's on a dsm?
Turbo questions
Catalitic converter
ic question
97 GS complete exhaust change need some help! backpressure?
Best tune up?????
Parts list and procedure for an Automatic to Manual Tranny Swap on a 2g DSM...
sohc to dohc engine swap
What do you guys reccomend for racing
whats a 1.8's threshold?
evo injectors
New offer
I need your opinion guys! Help!
Blow Off Valve
Alternator
what engine do I have?
Port and Polished Head..suggestions?
Gs
Intake Problem
So Desperate!!!
Are Ground Kits Worth It?!
Camber?
Which boost controller
spark plug question
4G64 CURSE need some help
Performance Chips..which ones?
put a turbo on a eclipse gs
Intercooler Piping Question
88 rx-7 verses 1994 eclipse gs nonturbo ???
more performance on a really fixed budget?
weight reduction question/1988 mazda rx-7 vs. mitsu eclipse gs 2.0L
I Am Seling 17 Inch Rims !!!
engine rebuild
Okay I need a little input...
new motor????
various responses about no muffler
Drilling out oil galleys?
Where TF DO I FIND PARTS!!!
Elecrtrical Problem
max boost?
