Our Community is 662,000 Strong. Join Us.
View Full Version : Mighty Max
  1. cracked head 86 SPX
  2. Blown Head on my 95 m/m
  3. Dianostic Light plug
  4. Electric Fan Wiring Diagram
  5. 2.4 blowing black smoke
  6. freeze plugs
  7. 91 mighty max 3.0 parting out
  8. Transmission maintenance
  9. '90 Mighty Max-Don't send ECM to these guys
  10. heater line question?
  11. 89 mighty max
  12. Engine Swap
  13. mighty max a/c
  14. 87 mighty max blackened plugs
  15. 89 Mikuni Carb
  16. OEM Radio
  17. A/C Compressor
  18. super clean 86 4x4 mighty max for sale
  19. 91 mighty max ecu
  20. tailgates
  21. Fuel Pump Replacement '90 MM-2.4
  22. smoke'n problem
  23. Need Help with OverDrive situation
  24. Fuel Tank
  25. Blowing raw gas out exhaust
  26. Fuel Filter Pump?
  27. parting out 90'-93'
  28. Cadillac Escalade Rims
  29. 1992 mad max truck 2.4l engne misfire code 41
  30. 1992 Mighty Max starting issue
  31. Might Max lift
  32. Wanted- 4x4 mighty max any engine or shape.
  33. Small Block V8 Swap
  34. EGR light on 1987 MM Automatic
  35. carb trouble
  36. mitsubishi mighty max altinator not charging battery
  37. interference engine???
  38. Engine Problems
  39. WANTED: Factory Service Manuals; 4D55 diesel engine, and '83 MM 4x4 truck
  40. Won't Start ECU rebuilt
  41. I might be buying a V6 and had a question
  42. I NEED HELP! 1990 2.4l
  43. exhaust manifold cover
  44. won't start
  45. 93 M/M Starter
  46. Replaced M.Max clutch and have a problem
  47. alternator will not charge my battery???
  48. won't start
  49. won't start
  50. 1989 2.0L TDC and Timing
  51. 91 mighty max codes
  52. Acceleration Power
  53. Engine Power
  54. I need a Fly-Wheel for a 85-90 Mighty Max!
  55. just got a 85 need help
  56. Oil Pump Problem
  57. Air cleaner
  58. Gas Mileage Chart
  59. Clutch Fork & Cable snapped for the 5th time!
  60. Shorter shifter for manual tranny on 2.4L motor
  61. gas gauge doesnt work
  62. Mighty Max, Poor mpg
  63. close to purchasing a D50
  64. 4d55 turbocharger
  65. Problem with the max
  66. Upper Control arms 1990 2wd
  67. Parting out my '94 xtra cab
  68. Engine bogging after bodywork
  69. I'm Going To Attemp A Motor Swap Need Some Help
  70. 93 Mighty Max
  71. Need help with timing
  72. 4D55 engine
  73. Water Pump is shot
  74. New to the board...
  75. help me
  76. Looking for a 4g64 engine
  77. 92 Mighty Max won't start
  78. Fuel Filter??
  79. need help diagnosing brake prob
  80. Can't find any lowering spindles
  81. Here is a new website about these trucks.
  82. Engine Swap
  83. A little racing history
  84. isuzu engine swap need help fast
  85. Valence / Air Dam?
  86. Need a starter for my 89 SPX Mighty Max
  87. Big Brakes
  88. HELP! I need advice as to what is wrong with my TRUCK!!!!
  89. Two quick questions
  90. 91 max from the ground up
  91. location of timing plate on a 2.4 liter
  92. balance shaft ?'s
  93. (Mighty Max '88) How do I take off the dashboard
  94. Help!
  95. Fuel leaking out of end of exhaust manifold
  96. Starting question???
  97. 250k miles Trans problems
  98. 88-95 mighty max body-dropped bed
  99. help 90 caliper Pin Bolt
  100. Lowering Your Mighty Max?
  101. Engine Color?
  102. Timing;Top Dead Center Positioning;crank shaft dispositioned
  103. WTB 2.4 Block
  104. negative battery cable
  105. '91 Mighty-Max clutch pedal
  106. '91 Mighty-Max Headlights
  107. Clutch options & '90 2WD Spec's???
  108. Radio Wiring Diagram
  109. Does a 4cyl. 4x4 trannys bolt up to a 6 cyl 3.0
  110. 91 Mighty Max No Start Click at ECU
  111. Bleeding Brakes
  112. i need a lift kit
  113. 4G63 swap
  114. looking for good parts company for mighty max
  115. mighty max 3000gt motorswap is it possible
  116. Mighty Max tranny problem
  117. Carb Problems
  118. turbo kits???
  119. motor swap
  120. Water Pump Question
  121. W.t.b.---90 4x4 Tranny..
  122. engine vibration
  123. 350 swap?
  124. horsepower
  125. mighty max cosmetics
  126. EGR Thermo Valve?
  127. Self Diagnosis Port!!?!!
  128. MPGs!?!?!
  129. Is there anything to lift front end?
  130. New Mighty Max Clutch on e-bay
  131. Maintenance Required Indicator Light
  132. sound system '87 mitsu pickup
  133. [WTB] Mighty Max/D50
  134. Swapping the Instrument Cluster
  135. 1992 Mighty max engine problems
  136. If you have a 1987 Mighty Max..i have a free Repair Manual for u
  137. Whats Slower?
  138. Mighty Max Front End Specs
  139. 3.0 v6 swap?
  140. 95 mitsubishi tranny problem
  141. 1995 mighty max Truck will not start?????
  142. engine problems
  143. Mighty Max Body Kits and Hoods
  144. Mighty MAx???????
