Old 04-23-2003, 08:26 AM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Question HELP! SOHC Install DX cam out, Si cam in
How would I go about replacing my stock cam in my DX motor with an Si cam I have now. Is it easy enuf for me to do?
Old 04-23-2003, 08:56 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
1 bolt to take off the cam gear, take out the valve train (couple bolts and it will all pull out, pull out the cam from the head, put new one in, then do the reverse to install. Its like a 30 minute job.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 04-23-2003, 08:59 AM
quiXilver's Avatar
Isn't there a way if I don't put the new cam in exactly right that I could mess the timing all up?
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 04-23-2003, 09:11 AM
There are like a "--O-" looking notch on the Dist side and a "-" notch on the cam gear side. It only goes on one way, you couldn't bolt it in wrong even if you wanted to.
Old 04-23-2003, 09:13 AM
quiXilver's Avatar
Ok thanks a lot I'm going to go try it now
heh I'll let you know what happends
B18A
Old 04-23-2003, 09:41 AM
quiXilver's Avatar
Of course this would happen to me....i acutally try to do something on my own, I broke 2 sockets trying to get the cam gear bolt off...wow.
Its just a cheap $5 set anyway-I guess I need to run and get a good one and try again.
B18A
Old 04-23-2003, 12:52 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Like was said above, its easy. There is a diagram floating around here somewhere.
Also, I can get you Si hubs and axles.
how to install type-r cams in 91integra?? scorpioq How-To's and Walk-Through's 4 01-09-2006 11:20 PM
difference between ZC SOHC, Z6, and Y8 cams Dweezil6969 Let's get Technical! 0 01-26-2005 01:04 AM
question abou installing an adjustable cam gear fooshman3 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 03-01-2004 10:30 PM
cams & cam gear installation $$$??? KEiTHo Integra 0 02-26-2002 07:22 PM
