Old 04-19-2003, 08:34 AM
Skeme1's Avatar
Skeme1 Skeme1 is offline
Question ECU codes
hey guys, lately i've been getting the check engine light and today i went to see what code i got. the only problem i have is, how do i read the flashes?
the light flashed more than 30 times (i checked the ECU codes section on 4thgenerationcivic.com and i noticed no code for anything with 20+ flashes)
lets say i got a code 20 for example, does it stop flashing after 20 or does it stop for a bit then flash 20 times again?
im confused..
Old 04-19-2003, 08:40 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
stops for a bit then starts flashing again
it'll flash once to say its on and working then it'll continuosly give u ur code
Old 04-19-2003, 08:44 AM
Skeme1's Avatar
it would flash about every 1.5 seconds (guesstimate)
Old 04-19-2003, 08:47 AM
1PhatCX's Avatar
just one flash? or like 15 flashes, like 2 second break, then 15 flashes again, just count all the flashes untill they stop for a sec then count em again 2 make sure u only have one code
Old 04-19-2003, 08:58 AM
Skeme1's Avatar
ok cool thanks alot!
Old 04-19-2003, 08:59 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
reset your ecu then check again to see what its giving you.
1PhatCX's Avatar
no prob
Ecu Codes GtRider Engine 6 11-05-2001 10:22 AM
Ecu Code???? GtRider Engine 2 10-19-2001 12:49 PM
Ecu Codes GtRider Engine 5 09-29-2001 08:14 PM
How to check ecu code on a 95 G20? gabani Maintenance 4 09-05-2001 05:23 PM
ECU codes barrlucas Maintenance 3 08-12-2001 12:32 PM
