Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 11-02-2001, 11:29 PM
GtRider GtRider is offline
Send a message via AIM to GtRider
Ecu Codes
can someone pleazeee
post Infiniti ECU codes....
and there meaningz!
94 G20t
Old 11-03-2001, 11:45 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
There are way to many to post. Didn't I post a code for you a while ago?
Old 11-03-2001, 01:06 PM
those codes that are on the se-r page,
are they 100% compatible with our G's?
it doesnt say that there are for Infiniti G20..
94 G20t
Old 11-03-2001, 06:33 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
Most of them are (the same as certain SE-R's), IIRC. If you need a code let me know and I will look it up in my FSM... But just like G-Forces said, there are way too many to post here. Maybe we could put up a page on G20.net one day, but even that is still kinda a lot of work.
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 11-04-2001, 06:04 PM
jbmays jbmays is offline
Send a message via AIM to jbmays
fsm
You have the factory service manual? How much did it cost, and is it worth it, compared to haynes or chilton manuals?
Jeremy
Old 11-05-2001, 12:07 AM
JustinP10's Avatar
Re: fsm
Yes, not much, yes. Look on E-bay. They should be under about $50 shipped. They are worth their weight in gold. (they are heavy too.)
Justin McClanahan
95 G20
Old 11-05-2001, 11:22 AM
Thanks, man. I figured they'd be about 50. I have the ones for my other car, and they don't make an aftermarket manual for it, so the fsm's are DEFINITELY a necessity.
Jeremy
Ecu Code???? GtRider Engine 2 10-19-2001 01:49 PM
Ecu Codes GtRider Engine 5 09-29-2001 09:14 PM
How to check ecu code on a 95 G20? gabani Maintenance 4 09-05-2001 06:23 PM
ECU codes barrlucas Maintenance 3 08-12-2001 01:32 PM
