Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-17-2003, 09:22 AM
Crow Crow is offline
Unhappy "Change Oil Soon" light
I changed my own oil, but cannot get the "change oil soon" light to go off. I followed the instructions to turn on the switch and pump the gas 3 time in 5 seconds, but that did not work. Any Ideas?
Old 04-18-2003, 07:02 AM
Weasel Weasel is offline
I have a GTP and the message centre is a bit different, but on mine you just hold the reset down, and it will go back to 100%.
Old 04-18-2003, 10:34 AM
Scott 02's Avatar
Scott 02 Scott 02 is offline
Banned
Send a message via AIM to Scott 02 Send a message via Yahoo to Scott 02
Yep, should be a yellow reset button under the dash.
Old 04-18-2003, 03:52 PM
grandprix92's Avatar
grandprix92 grandprix92 is offline
Send a message via AIM to grandprix92
yep. that sounds about right to me.
Done: 1969 Baldwin Camaro
Old 05-16-2003, 12:26 AM
Blue02R6 Blue02R6 is offline
If a door is open when you pump the gas pedal it will not work.
Old 05-16-2003, 05:55 AM
Scott 02's Avatar
Banned
What switch?
Old 05-16-2003, 11:13 PM
pcv pcv is offline
Sit in the car, Shut the door. Turn ignition on, do not start the car, and pump the gas pedal three times within 5 sec. and wait till the light starts to flash. You might have to do it 2 or 3 times. Give it about 10 sec. between tries. Have done it lots of times. You'll get it.
Old 05-18-2003, 08:19 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Make sure you are not pumping your foot as fast as you can! It has to be 3 pumps fully from closed to fully open 3 times don't worry about the 5 second part and if the 3 pumps don't work just keep pumping. I change oil on these cars all the time and I can't do it without pumping at least 15 times.
Old 06-01-2003, 10:55 PM
JoeJoe231455 JoeJoe231455 is offline
On my 01, there is a reset button on the dic. All I have to do it hold that button down for 10 seconds, while it is on the "oil" display and it resets.
Old 07-02-2003, 06:09 PM
BlackevoVII BlackevoVII is offline
Send a message via AIM to BlackevoVII
I am sure this is an old message.....but its probably an o2 sensor or some sensor. I had the problem of my oil light always coming on and going off.
I dont want to help you. Hurt me, Abuse me, trick me, im a fool. With all you given me, why would i want to help. Opened myself to you, only to have the door shut. trapped in seclusion, inside this enclosure i find the real meaning of loving myself. Hurt from the force of your attack, but no more, never again. I would have given the world to you, but you were just too good for that. You brush me off and i only try harder, yet i refuse to be a part of your game this time. I dont hear you, your words, invisible, nothing but space to my eyes. You extend your hand, but i pretend not to see it, just like you pretended not to acknowledge me. Life sucks, thank you for making mine all the more clearer. Welcome to my world.
Old 06-02-2006, 01:21 PM
wahta_mohawk wahta_mohawk is offline
Re: "Change Oil Soon" light
I had this problem too with my 2002 GT . I was told to "floor" the gas pedal slowly 3 times while the engine is OFF and this resets the change oil light.
I tried it and it works !
Old 06-02-2006, 02:37 PM
BNaylor's Avatar
BNaylor BNaylor is offline
I am giving you a warning. In the future, please do not resurrect message threads that are this old unless there is good cause. The post before yours was almost three years ago. The answer was properly provided in prior posts by others so there was no reason to resurrect it. Thank you for your cooperation.
Excerpt from AF Community Rules:
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread.
Timeslip 08/12/06
AF Community Guidelines
Does the oil warning light have an oil level switch? dieter Caravan | Voyager 5 08-29-2009 03:36 PM
97 Pontiac Trans Sport Oil Pressure light mspontiac Trans Sport 2 07-07-2009 05:52 PM
93 PA "change oil soon" light hotrod_chevyz Park Avenue 5 07-09-2007 09:50 AM
How do I reset the "Change Oil Soon" Warning? ibelta LeSabre 2 09-01-2005 01:03 PM
How do I reset "Change Oil Soon" light caseybird SC/SL/SW 9 07-11-2004 12:30 AM
Closed Thread
