93 PA "change oil soon" light
how do i reset it?
IIRC, 1993 was the last year of the reset under the passenger side dash. Look at the sound insulator above the passenger floor-well and you will see a small hole in the front side. Turn the ignition on, then use a small object such as a Phillips head screwdriver, to insert in the hole. There is a button behind the hole. Push in and hold the button until the “change oil soon” light on the upper dash, flashes two times. At this point, it is reset.
Knowledge can be communicated, but not wisdom! ![]() ![]() |
Re: 93 PA "change oil soon" light
sweeeeeet.
Bo, I'm exercising so much restrant at the current moment with this.
Only Dylan could interpret something like this:
![]() BTW, good job Dylan, after reading it your way I also, required some restraint! ![]()
It was rough.
