Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 10-28-2001, 01:01 AM
Corion Corion is offline
Send a message via AIM to Corion
driving stick and potential problems
My max is my first stick car and I think im fucking it up! Ive been driving for about 3 weeks now and Ive grinded gears twice and accedently shifter to second rather than forth(majorly over the red line)2 times also, I get a gas smell sometimes and a burning smell others, any ideas? and also when i accelorate quickly the wheel turn to the left why is that?
Old 10-28-2001, 01:01 PM
Cyko Cyko is offline
LOL
Well, the good think is that most of the time you shift from 1-2-3-4-5th gear and then you don't put in Rocket.... hehe (Reverse). Well, I'm having the same problem with my maxima but the wheels go to the right. I need some advice on that too. Thnx
Old 10-28-2001, 04:04 PM
irvine78 irvine78 is offline
Send a message via AIM to irvine78 Send a message via Yahoo to irvine78
Re: driving stick and potential problems
just practice driving your car before you try to drive fast...
when people who aren't used to driving stick tried to push their cars, they end up grinding gears and miss their gears yet...
that burning smell is from your clutch..you're just eating up your clutch..another common thing for inexperienced drivers...don't rev up your motor too much when you engage your gears and don't do half-clutch too much..this will shorten your clutch life considerably...
as far as the wheels turning, that's just torque steer...
Maximadriver.com 2DMAX of Jan/Feb/March
Check out my new homepage!!
http://www.cardomain.com/id/irvine78
mods:Stillen/Premier custom intake, Stillen y-pipe, Stillen front strut tower bar, Stillen rear sway bar, Stillen touring front lip, Stillen side skirts and rear valence, GReddy Evolution cat-back, MSD In-line fuel pump, 2 B&M fuel pressure regulator set at 45psi with VDO read out gauge, Unorthodox racing UDP, Custom 8puck racing clutch/pressure plate, 100shot NOS, Eibach springs, KYB AGX shocks, 300ZX TT front calipers, 12.4inch 3000GT VR-4 cross drilled/slotted front rotors, custom rear superslot rotors with AXISS metal master pads, SS breaklines, red painted calipers, Joshua Tree carbon fiber dash kit, Pacesetter short shifter with MOMO knob, aluminum RAZO pedals, panasonic head unit, Alpine amp and single 12" JL sub, autometer air/fuel, oil pressure guages, Gunmetal Gray 18x7.5 AXIS SE7ENs with 225/40/18 Falken tires/19x8 WORK ESPERIO IIs with 245/35/19 Yokohama AVS Sports, front/rear clear corners, factory fog lights, factory spoiler and 00-01 SE tail lights, AE headlight conversion, JDM style yellow Raybrig blubs up front/rear, APEXi RSM.....shoot...did i leave something out?
Old 10-28-2001, 04:51 PM
mtrai760 mtrai760 is offline
Send a message via AIM to mtrai760
If you over-Reved your engine you might want to check your compression and have your engine checked out, you could have easily bent a valve at 8k+ if you exceeded that...
You must learn to walk before you run... Learn to drive the stick first, then learn to drive it fast...
5spd VLSD
15.2@92mph
180hp & 193tq
Faster than jOO!
A hunting we will go...
Old 10-28-2001, 09:51 PM
yea i got a little trigger happy it went to about 7.5 both times i did it not to the full 8 still scared the shit out of me, how come hondas (vtec) can rev up to like 9? is there a way to make it safe for maxs to rev that high
Old 10-28-2001, 09:54 PM
Jay! Jay! is offline
Horizontally Opposed
Hondas that rev that high have much less displacement and less mass moving around.
Learn your shift gate. Know where each gear is. If it doesn't want to go into the gear you're pushing towards, don't force it. Your warranty is not going to cover it if you downshift 3 gears instead of one and blow your engine. Be careful, please.
Hierarchy of Subaru:
(Click to see mine!)
Old 10-28-2001, 10:05 PM
MaxRX7's Avatar
MaxRX7 MaxRX7 is offline
with practice, you could shift mad quick yo !
remember to always "enjoy the ride" ! :flash:
Maxima parts for sale:
http://home.comcast.net/~luisrx7/MaximaParts.htm
Old 08-01-2002, 10:32 AM
adv adv is offline
Learn to feel your clutch travel. Learning where your clutch first engages (you'll feel the engine) is the key to driving stick, not the gears. How do you confuse 2nd and 4th, you're probably trying to kill the gears. You'll notice if you disengage your shifter in any gear it will automatically pop between 3rd and 4th, and it's up to you where you want to shift it from there 1st, 2nd, 3rd,.... good luck!
2002 explorer v8 4wd eb high idle and shifting problem BAKERCONTAINER Explorer | Explorer Sport Trac 0 02-03-2010 01:22 PM
1994 voyager ac and heat problems bitco Caravan | Voyager 2 10-20-2009 08:49 AM
driving noise and 4wd problem metallica21156 Problem Diagnosis 3 02-16-2007 08:44 AM
Someone Help me drive Stick!! TheChosen Off-Topic 5 01-20-2002 04:55 PM
