Old 04-14-2003, 02:30 PM
emil13si's Avatar
emil13si emil13si is offline
Question ECU what type???
I need your help guys!!!
I don't know what type of ECU I have it's of the civic 96' engine B16A2 as if I understand it right it supose to be OBD1 is that right ???
So here are the numbers that are written on my ECU:
37820-P2T-G01
937-100537
So here is the trick qustion I already ordered a HASport kit, so I'll get it in aperiod of two weeks, here are the parts that I bought:
-mount kit
-shift linkage
-Wiring harness for engine swap B16A1
So here is my big problem how to make that Wire harness for my engine B16A2 is there any "plan" or "how to" on net...PLEASE help me
So if I get that right I'll get the wire for OBD0 but I need the wier harness for OBD1!!!
THNX for all your help
Powered by
CivicTypeKoshiR
Old 04-14-2003, 02:33 PM
Civic Rush's Avatar
Civic Rush Civic Rush is offline
Send a message via AIM to Civic Rush
Re: ECU what type???
on a 96' it is OBD2 man
This is the real melt pizzle
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
if it actually is a 96 ecu, its OBD2 then
*edit...same time.hehe
SOLD!
Old 04-14-2003, 03:15 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
pt2 is from the 6th gen si. U need to get rid of the ecu and get urself an obd1 ecu then get a jumper harness. Its alot of work.
Old 04-14-2003, 03:32 PM
emil13si's Avatar
So how can I get my swap easier, we are already mofifying the engine tha is from 96' civic that is why I'cve got all the wiers and this ECU with ABS control unit and everything...
Help needed BAD!
THNX
P.S.: make a list of parts that I'll need cause the engine is coming in this summer-tuned, so I must figure out how to wier it!!!
Powered by
CivicTypeKoshiR
Old 04-14-2003, 03:40 PM
mellowboy's Avatar
Ok ur getting that first gen b16a harness rite? hmm... lets see try this...
Get urself a first gen b16 distributor, fuel injectors and a pr3 ecu. U dont have to deal with all that converting bullshit.
What types of metal can I weld with Ox/Ace set up, and what kind of fillers do I need Andy98111 Metal Shaping and Welding 2 08-02-2008 02:34 PM
ecu for type s integra s Integra 1 07-22-2007 06:08 PM
When Getting Eprom Ecu, What should I be concerned with? Savior1974 Off-Topic 2 10-14-2004 09:45 PM
CODE 16, form my ECU - what should i go check?? DJHyperXK2004 Engineering/ Technical 1 08-13-2004 10:03 AM
p40 ecu -- whats it from? Gusto222 Engineering/ Technical 0 12-22-2001 12:48 PM
