Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 04-13-2003, 02:48 PM
$ilverbullet $ilverbullet is offline
Send a message via AIM to $ilverbullet
what oil?
hey guys, i've been seeing alot of high preformance oil commercials(Royal Purple, Z-Max, Quick Restore, etc...). Most of them claim to "microlubricate" your pistons and chamber and restores older engines and gains HP. Is any of that true? Are they allteh same or are certain ones better than other? Any input would be apprciated.
My 1993 240SX SE Fastback
Old 04-13-2003, 03:06 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
I really don't believe any of their claims for those products and would refuse to put them in my engine.
Old 04-13-2003, 03:15 PM
Jetts's Avatar
Jetts Jetts is offline
Send a message via AIM to Jetts
i think they are bull, but they might be true
i dont have the equimpent to test their notions but i wouldnt spend the extra money
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Keith. higher then any mother fucker out there..... R.I.P homie..
Old 04-13-2003, 05:28 PM
Spectrum Spectrum is offline
Send a message via ICQ to Spectrum Send a message via AIM to Spectrum
Royal Purple is very good oil, tests prove it. As for oil additives, those are mostly bullshit.
Old 04-13-2003, 05:39 PM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
just use a good known brand like mobil 1 or castrol syntec. They also have some special oils for high mileage engines.
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 04-13-2003, 06:22 PM
94svt5.0's Avatar
94svt5.0 94svt5.0 is offline
Basically the only thing that gives some of these brands any advantage is being synthetic. Smaller molecular structure allows it to be more slippery, therefor minimizing friction, hence gaing a couple HP. But, in slightly worn engines the smaller atoms of the synthetic cause it to slip around rings and seals. Causing leaks and oil consumption. There is no "bonding" occuring between any oil or aditive to pistons ect.... Basically if you change your oil frequently there really is no need for the extra cost of synthetic.
More photos and Info/website!
1994 Cobra
-off road h-pipe
-superchips power chips
-mac cold air induction
-BBK aluminum underdrive pullies
-pro-m 75mm bullet MAF
-18" konig wheels with nitto 555 zr tires
-Ford Racing 65mm throttlebody
-Ford Racing king cobra clutch
-Ford Racing 3:73 Gears
-Ford Racing Aluminum driveshaft
-Bullit suspension/ springs,shocks,struts
-Aubrun HD limited slip Diff.
2002 subaru Impreza RS
- stock
1989 Toyota pickup 4x4
-K&N
Old 04-13-2003, 08:44 PM
How frequently you change your oil has nothing to do with how it performs, synthetic will always perform better.
Old 04-13-2003, 10:20 PM
fatninja19 fatninja19 is offline
Send a message via AIM to fatninja19
I suggest you pour some of each name brand oil into your car.
when in doubt, throttle.
Old 04-14-2003, 10:00 AM
NSX-R-SSJ20K's Avatar
NSX-R-SSJ20K NSX-R-SSJ20K is offline
Send a message via AIM to NSX-R-SSJ20K
don't use synthetics in Rotary's that is all :o
Qualified Automotive Engineer
Old 04-14-2003, 03:02 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
hmm...
you're comparing royal purple oil (which is really high quality stuff)
with additives like z max.
compare oils to oils...
use a high quality oil as noted...
royal purple falls under high quality oils for me...
Old 04-15-2003, 10:40 PM
why not? burns too quickly?
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
