Go Back   Automotive Forums .com Car Chat > Buick > Regal
Old 11-25-2009, 11:58 AM   #1
jake71
98 regal starts then dies
I have a 98 regal 3.8 supercharged.It starts then dies.I replaced the fuel pump and crank sensor.It has no check engine light on or security light on.
jake71 is offline   Reply With Quote
Old 11-27-2009, 01:29 PM   #2
BNaylor
BNaylor's Avatar
Re: 98 regal starts then dies
How about the fuel pump resistor? You can run a bypass on it to troubleshoot. Let me know if you need the procedure. The L67 engine has a two speed fuel pump system with two fuel pump relays. One is a fuel pump speed control relay to give full fuel pressure at startup.
And welcome to AF.
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline   Reply With Quote
Old 12-08-2009, 11:38 AM   #3
sea-doin-it
I have a thread about my 97 GS Fuel Pump not running, I looked for this resistor buy can not find, could you send me info on the procedure? Do you know how to check voltage at the pump? I know my pump is not running, and I do not have fuel pressure at the fuel rail on the engine.
sea-doin-it is offline   Reply With Quote
