Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 04-01-2003, 07:52 PM
ac427cpe's Avatar
ac427cpe ac427cpe is offline
Miata is always the answe
Send a message via AIM to ac427cpe
TPS adjustment
ok.... i've looked everywhere, how can i adjust the TPS on my N/A 87 rx7? it's gone stupid on me... please help!!!
hello, i am Dan
No more project cars. I wonder how long that will last...
Old 04-02-2003, 12:54 AM
Evomaniac's Avatar
Evomaniac Evomaniac is offline
Banned
why don't you try your search engine, how can I use it anyway's, can't seem to figure it out.
The TPS is the black plunger in the center. The screw in front of the TPS is used to make adjustments.
The TPS is part of the Fuel and Emission Control System. It has two major functions: To cut the fuel off when you snap the throttle shut from wide open throttle. (This prevents backfires...) And the sensor also tells the ECU the position of the throttle body. This allows the ECU to make adjustments to the air/fuel mix at different throttle positions.
Most common signs of a bad TPS is a car that runs rough at Idle or a car that has a hesitation problem during acceleration. Bad backfiring could also be a TPS, but backfiring is usually caused by having an aftermarket free flow exhaust.
NOTE! There are two types of throttle position sensors. The 86-88 cars have a single piston TPS, the 89-91 cars have a dual piston TPS. The 86-88 sensor is not inter changeable with the 89-91. However they are adjusted exactly the same!
you're car has a single piston located in the black plunger in the center, hope it help's.for more info go to http://home.rmci.net/panther/tps.htm
-Dave
Old 04-02-2003, 11:38 PM
ac427cpe's Avatar
awesome... i knew what it was and did, just not the lighting sequence! thank you thank you thank you!!!
hello, i am Dan
Old 04-02-2003, 11:45 PM
Evomaniac's Avatar
Banned
you're welcome.
Old 04-03-2003, 11:31 PM
ac427cpe's Avatar
i made a TPS lightbulb contraption! it looks cool! and... tells me that the tps of my car is waaaaaay out of wack! fixy tomorrow.... details to come
but yeah... the lightbulb thing works!
hello, i am Dan
Old 04-04-2003, 12:02 AM
Evomaniac's Avatar
Banned
that's good to hear, I got my 22b engine and well it's what i had expected, it's say's sti all over it it's in the egine bay right now but nothing is hooked up, i got my aftermarket ecu to work with the 22b also, i'm going down 0.3 liter's i used to have a 2.5 now i have a 2.2 but now i got more power,cool.
-Dave
Old 04-04-2003, 12:05 AM
ac427cpe's Avatar
22b?
hello, i am Dan
Old 04-04-2003, 12:15 AM
Evomaniac's Avatar
Banned
ej22 that came stock in the 1998 subaru sti version II I think, because version III was 4 door.the 1998 subaru 2.5rs comes with ej25 stock i'm just getting a ej22 sti engine for the power and it has all the work's done to it already from the factory, balaced and bluepruinted to handle 700hp+ I just need to get a turbo to give me those number's.
-Dave
Old 04-05-2003, 03:06 PM
ac427cpe's Avatar
oh, cool!
btw... the lightbulb fix, WORKS!!!!!!!! yay!!! MY CAR IS HEALED!
hello, i am Dan
Old 04-05-2003, 04:53 PM
Evomaniac's Avatar
Banned
that's coool, good but I doubt that your car is healed.
TPS Adjustment joeyd50 Engineering/ Technical 3 09-05-2004 11:06 AM
TPS adjustment rruddfan21 Metro 3 07-23-2004 06:21 PM
Is a TPS adjustable? quiXilver '88 - '91 Civic | CRX | Wagon | Shuttlee 19 03-21-2004 07:25 PM
2000 V6 TPS adjustment Davejb Rodeo | Passport | MU 5 02-02-2004 09:12 PM
TPS adjustment settings? O.P Bonneville 3 09-09-2003 07:27 AM
