Old 02-21-2004, 11:20 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Is a TPS adjustable?
I just changed, my map, tps, and O2 sensors. Now the car will start up fine and idle at about 2grand, then after about a min, it will drop to around a grand, then right back up to 2, then down, then up, and it does this about every second for about 15-20 seconds, then it's fine. Only does it when the motor hasn't been running for a long time. Just one question...WTF? I'm thinkin the new TPS is fucked up...but i donno, I'm ready to just run the damn car off a cliff, with me in it...
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 02-22-2004, 12:01 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Re: Is a TPS adjustable?
No - do NOT fuck with the TPS. Honda sealed it for a reason. If the non-adjustable screws have been messed with then that's your problem. Go to the wreckers and get a non-tampered throttle body.
Just re-read your post - why the fuck did you change the sealed TPS? Dickhead
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 02-22-2004, 04:07 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
hey should i get a TB for my adctualy engine (91 ex) or will a newer one work and/or work better? i thjink my tps is bad too but hearing this makes me realize i shouldn't just change the tps
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 02-22-2004, 05:21 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Re: Re: Is a TPS adjustable?
I changed out the TPS on my y8 throttle-body... So, it won't work? The only reason I did that was because I didn't wanna hafta buy a whole new throttle-body.
Old 02-22-2004, 08:37 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
you didnt adjust the timing screw on your throttle body did you? if so let your car warm up and adjust it back to where it was...your car should idle about 850ish rpm's when warm upped.....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 02-22-2004, 09:52 PM
Jay eS Iye's Avatar
i've actually thought about adjusting the idle, maybe i can lower it and it'd be fine, how do i do that?
and i'm getting conflicting answers, can i just replace the tps?
Old 02-23-2004, 06:09 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
You can calibrate the TPS. It should be like .5v close and 4.5v wide open. You will need a multimeter to do that.
Old 02-23-2004, 08:19 AM
lilol89crx lilol89crx is offline
i agree.....i do this all the time and never had a problem.
then how are you supposed to use a aftermarket TB say like bbk which doesnt come with a TPS......
Old 02-23-2004, 03:33 PM
Jay eS Iye's Avatar
i'll take that as my answer and look for either a TB with TPS or just the TPS, whichever i find a better deal with.
also, are any TB's better than what i currently have on my a6? i'm still wondering
and lastly, anyone got a TB wtih TPS for sale, or just TPS?
Old 02-23-2004, 03:35 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Yea, why does everyone think that if its tampered with, its garbage? Just break out the good ol voltmeter.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 02-23-2004, 05:50 PM
ci5ic's Avatar
So what happens if you get a voltage different from what is described above? How do you actually do the adjusting?
Old 02-23-2004, 05:53 PM
loosen the screws that hold it in and adjust it left to right, just like you adjust timing by loosening and moving your distributor. same concept.
ZC stuff
Old 02-24-2004, 12:45 AM
quiXilver's Avatar
Ok, I just now got back on, the reason I replaced it is 'cause I'm going nuts trying to find out wtf my problem has been, so I've replaced all the main sensors, and now I have more problems. My car Idles really high, like 1200 rpm, always has.
It only does this when it's cold, and for a short period of time...still say it's tps?
BTW Setanta, the damn thing just has 2 screws on it, then it comes right off, how is that any more "sealed" than anything else?
B18A
Old 02-24-2004, 06:24 AM
Setanta's Avatar
The "screws" are sheared at factory and also sealed. Most drill them or multigrip them out and replace them with standard ones - usually resulting in a stuffed idle (also check the FIV).
As for using multimeters etc - enjoy. You still rarely get it spot on - if ever. You can turn all you want - but when you tighten the screws it can mess the setting.
Hey - what do I know? Apart from the fact that a TB with sealed TPS off an XSi cost me Au$50 (less than that in US currency) and it bolted straight onto my SiR's B16A and immediately fixed 90% of my idle problem (rest was the FIV). That was after cursing the dickhead in Japan that had messed with the TPS.
'99 PY DC2R
'85 BBS BMW E30
Old 02-25-2004, 01:24 AM
quiXilver's Avatar
FIV=?
B18A
