Old 03-30-2003, 07:07 PM
Gogeta195 Gogeta195 is offline
Send a message via AIM to Gogeta195
B20 vs B18c5
Which is better, B20 or B18C5?
Why?
What are their statistics?
How much do they usually run as far as money is concerned?
Remember to drive safe!
And street racing is illegal!
Digital Dreadnaught is a puppet of the devil.
http://ddc.cc
Sleeper
2004 Honda Civic EX Coupe
Old 03-30-2003, 09:15 PM
anthony417 anthony417 is offline
as for the B18C5.........
1797cc (1.8L) DOHC VTEC
197hp/134trq
11:1 Compression Ratio
Hydraulic LSD Transmission
$5999
+ Shipping from
http://www.streetimports.com/homepage.htm
Old 03-30-2003, 11:44 PM
zippeay zippeay is offline
DO NOT GO TO STREETIMPORTS!!!!!!!! I got my engine from them and THEY SUCK!!!! I've had more problems with my engine than I know what to do with. As far as the difference, the B18C5 would be more reliable and have probably more torque than B20 depending on how you build the B20 and what trans you use. The problem with your question is you can build a B20 Vtec to do a lot it just depends on how you build it, but if you build a mild setup it will most likely cost you less the the B18C5. If you want a daily driver I would go with the B18C1 or a B16A there both really good engines and put out a lot of hp. Its up to you though
Old 03-31-2003, 04:26 PM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Stock USDM B20b
Compression 8.8:1
Horsepower: 126hp @ 5400
Torque: 133lb-ft @ 4300
This motor comes WITHOUT VTEC, comes out of a CRV.
Stock B18c5
Compression: 10.6:1
Horsepower: 195hp @ 8000
Torque: 130lb-ft @ 7500
This motor has VTEC, comes out of an Integra Type R.
First off let me start with saying you are comparing apples to oranges here. I dont know if you are talking about CRVTEC or just the plain old CRV motor. Either way, this motor has far more potential IMO when it comes to tuning.
Why you ask? Because the B18c5 is a B18c thats already been worked. Think about it, Honda built this motor to be good out of the box - its very hard (note EXPENSIVE) to mess with perfection.
B20 on the other hand was never really meant to be a tuner motor - however being that Honda motors are so easy to swap, any idiot with half a potato chip IQ for a brain can see the direct benefits. The old term theres "no replacement for displacement" holds true even to Honda. Look at t he torque numbers - 133ft-lbs @ 4300 RPM vs. the Type R's 130ft-lbs @ 7500 RPMS! Your making more torque in the CRV motor before the Type R even engages VTEC! Whats this mean? Even stock for stock, you could take a Type R swap off the line... However if both motors were stock, the Type R would eventually real you in and pass you.
For the price of the Type R swap, you could build a hell of a CRVTEC swap (B20 block w/ VTEC head) or hell turbo the sucker! Either way CRV is the way to go. Let me know, ive got plenty of motors to go around! :smoka:
AF's Official Asshole
RIP AUNIE
Old 04-01-2003, 05:26 AM
So what if I took a B20 longblock and a B18C5 head and put them together? How much horsepower/torque are we talking then?
What about cost?
http://ddc.cc
Sleeper
Old 04-01-2003, 01:53 PM
The head will probably be a lot, why not just get a B16a head or a GSR head, the only difference I think between the B18C5 is the cams. You'll have to research the head not too many places are gonna sell a B18C5 head, but I'll bet your gonna pay out the ass for one
Old 04-01-2003, 07:32 PM
jeelani jeelani is offline
Send a message via AIM to jeelani
More displacement means more torque, therefore a b20 would have more torque. The b20 also has lower compression and is stronger so it will be more reliable. A B20 with B16 head and GSR transmission would be your best solution.
Old 04-01-2003, 09:04 PM
Alrighty,
So what kind of modifcations do I have to have to make this whole scheme work together? As far as lining the head up with the block, getting the transmission to line up with the block, it all sounds kind of difficult. But I guess this is not something easy. As far as the engine is concerned, what do you think the output hp/tq would be?
http://ddc.cc
Sleeper
Old 04-01-2003, 10:03 PM
Do a search for CRVtec and there are a ton of sites that go through on how to do it step by step, but if you don't shit about cars I would even mess with it. Find a shop and have them do it, it will cost you more but it will probably be done right. As far as transmitions go all B series trans will bolt right up to any B series block, hence a B16a trans will work B18C will work, got it??? Good luck
Old 04-01-2003, 11:58 PM
Prelewd's Avatar
Prelewd Prelewd is offline
Send a message via AIM to Prelewd
Neither, just build a B16 and be happy with the money and headaches you save. I don't believe you should frankenstein hondas, they are harmonious the way they are. It's your time and money though.
Soon..
Cars:
1990 Nissan 300zx Twin Turbo
1992 Honda Prelude Si 4WS H22a Swap - For Sale
1965 Chevrolet 1/2 Ton - 500ci Cadillac Cometh
1970 Datsun 240z - For Sale
1972 Datsun 240z - For Sale
1977 Datsun 280z - For Sale
1991 Infiniti Q45 - Engine Donor to 240z - Parting out the Rest
Sold Cars:
1976 Jaguar XJ-S - Rear end Donor to Chev Pickup
1971 Datsun 240z
1984 Civic 1500 Hatch
Old 04-02-2003, 01:05 AM
york2600 york2600 is offline
Send a message via AIM to york2600
B18C5 head is a B16 head which is better for valve clearance in a B20VTEC setup, but produces slightly lower compression due to the dome. It has more than just cams over the B18C1 head. It has a mild port/polish, better valves, and improved springs. That's why you get the extra 200rpm on the redline.
94 Integra GSR Coupe
Mods: Professionally Built B20/VTEC: B18C1 head w/ pocket port, JE oversized pistons, Eagle Rods, block guard, ARP head studs, Skunk2 Intake Manifold, STR Throttle Body, AEM CAI, AEM Fuel Rail/Regulator, RC Engineering 280CC injectors, Denso Iridium Plugs, Magnacor Wires, DC Sports 4-2-1 SS Header, Greddy Evo Exhaust, ACT Stage 1 clutch W/ ACT flywheel, Apexi SAFC & Revspeed Meter, and many other toys.
Old 04-02-2003, 07:44 PM
Cool I didn't know that, you learn something every day, thanks
Old 04-04-2003, 12:51 PM
94delsolSI 94delsolSI is offline
alright a B20 would take a type R for like the first .5 sec. of a race stock a B20 is best matched with a B16 head and most common but you have to route the oil which as a couple things of machining to do and the intake manifold produces a little better top end power B20 the sleeves are weak so those would need to be replaces you would need a block girdle which takes a little time to install. you would probably want to raise the compression a little bit cause that compression is not for performance engines on the type R you could also raise the compression a little bit and other then that it is small mod's like fly wheel adjustable cam gears, cam pulleys and stuff like that. the B20 doesnt have very much aftermarket support considering it belongs in an SUV
Old 04-04-2003, 04:23 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
197hp/134trq
$5999
+ Shipping from
Are they on crack!?!?!You do realize that,tha tmotor goes for about $1600 less than that right?And 11.1:1 cr?You really shouldn't post shit like that.Sleeve it,new rods,pistons,etc...get the dowel and oil lines machined in and go crvtec,here is a link with more info on a crvtec build up.
Old 04-08-2003, 09:27 AM
D2daT2daM D2daT2daM is offline
197hp/134trq
$5999
+ Shipping from
:flash: for 6gs you can have a nice awd talon tsi, godamn thats too much for a b18c5 4500 should be the most and thats even too much for a 4 banger
to b20 or not to b20 that is the question mcna '88 - '91 Civic | CRX | Wagon | Shuttlee 4 08-22-2006 09:37 PM
B20 VTEC vs. B20 Turbo ahzab33 Let's get Technical! 12 03-17-2004 10:51 PM
Swap: B18c5 or H22a? iLLuCiv99 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 14 05-12-2002 02:43 AM
B20 long block+b18c5 head=? TrUnKs714 Engineering/ Technical 11 03-09-2002 08:04 AM
will a b18c5 fit 82civicwagon Engineering/ Technical 6 12-14-2001 06:41 PM
