Old 03-27-2003, 05:23 PM
NicoB16A2 NicoB16A2 is offline
Turn (hazard) lights instead of parking for alarm flashing
Hi. When I installed the alarm (an Ungo MS7000) I wired the flashing signal to the parking lights wires, so when I lock/unlock, it flashes the parking lights.
Since I normally don't like to use the chirp confirmation, just the flashing, i would like the alarm to flash the turn lights instead, because they are much brighter and easier to see (especially from the sides).
Since the bulbs for the turning lights are 25W each, and the parking lights are only 5W, I'm afraid that the increased power consumption might be too much for the alarm 12V signal for flashing.
Has anybody tried this succesfully? Recommendations? Will I have to use a relay (cumbersome)?
Also, does anybody know where to find the wiring for the turn signals (both left and right circuits) in the Civic hatch 98? Thanks a lot
Nicolas
Old 03-29-2003, 07:37 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
most alarms uses a relay internally for the flashing, and some use an external. A relay is not all the bad cuz you can always stuff under the dash with the rest of the wires.
Old 03-29-2003, 10:49 AM
Anyone knows the wires (and location) for this hookup?
Old 03-30-2003, 03:34 PM
91EF3ZC's Avatar
91EF3ZC 91EF3ZC is offline
AF Premium User
Send a message via AIM to 91EF3ZC
hazzard switch, or steering colum
Visit my EF page:http://www.pbase.com/luv2hover/91_civic_&page=all
turn signal lights not working x3mtm Durango 4 01-11-2010 12:49 PM
'95 Sidekick JX wiring problem, park lights Bdamdifino Sidekick 0 12-05-2009 04:25 PM
Custom wiring troubles for 94 Suburban Front Park/Turn Signal Lights mdg911.com Exterior | Bodykits | Lighting | Aerodynamics 0 03-13-2006 07:25 PM
HELP! parking/turn signal lights won't shut off bullzeye19 Alero 4 11-10-2004 11:33 AM
