Old 03-27-2003, 06:28 AM
92teggsr 92teggsr is offline
fuel cut-off at 3500 on new ZC motor!!! Anyone know why ??
My friend just bought a 94 honda civic cx with a new ZC motor in it. I went with him when he bought it two days ago and the ignition wiring hadn't even been finished so the motor had never been ran in the car. He connected the ignition wires and had the car running in about 10 minutes and it seemed to work fine but when he started to drive it the fuel cut-off was at about 3500 RPM. (it feels exactly like fuel cut-off at least) At first we thought it was the ECU but we hooked up the one out of my 92 gs-r and it did the exact same thing. Obviously some wires are connected wrong somewhere. Anyone have any idea which wires they could be? Could it have something to do with the cam sensor or the throttle positioning sensor? Please reson even if you only have an idea of something that might work. Thanks
99 Honda Civic Si
Stage 2 Clutch
SPP Exhaust
Short Shifter
Eibach Suspension
17's
91 Honda Accord LX
Old 03-27-2003, 08:51 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
well the zc is a d series engien. and the ecu your runnin is a b series ecu. idk if that might be a problem. also are u getting thrown any codes ? cause usually when it does that, there something wrong sensor wise with the motor. they call it limp mode on th ecu cause theres something wrong so the comp goes into limp mode
Team Lonely Drivers
Old 03-27-2003, 09:18 AM
we've tried a B-series ECU and a D-Series ECU but it didn't make any difference. I'm guessing it's a sensor too but when I looked I couldn't even find that plug where you plug that little tool in. I looked down by the ECU but it wasn't there. Do you have any idea what sensor it could be? I'm thinking cam sensor or throttle positioning sensor.
99 Honda Civic Si
Stage 2 Clutch
SPP Exhaust
Short Shifter
Eibach Suspension
17's
91 Honda Accord LX
Old 03-27-2003, 12:27 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
Which ZC motor did you put in the car? The DOHC model or the SOHC ZC VTEC motor?
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 03-27-2003, 07:32 PM
the DOHC 130HP non V-Tec.
I called honda today and talked to one of their technicians to see if he would know anything. He said he doesn't think it's the Throttle positioning sensor because it would still let the car rev higher but it would just make it run a lot worse. He said it wouldn't be the cam sensor cause then the car wouldn't run at all. He thinks it might be the timing. I looked at the cam pulleys and one was just a little off. (maybe one degree) I don't think it would cause the fuel cut off to be at 3500 rpm though. Do you guys think it's posible that we wired the ignition wires up wrong. All cylinders are working but maybe it was another wire. Does anyone know a good webpage that might explain this stuff? Anything will help. thanks
99 Honda Civic Si
Stage 2 Clutch
SPP Exhaust
Short Shifter
Eibach Suspension
17's
91 Honda Accord LX
Old 03-27-2003, 07:38 PM
i would have thought the cylinder sensor thingy, the one that determines tdc. i forget exactly what the sensor is called
Team Lonely Drivers
92 jimmy 4.3 votex code 22..new tps...help with fuel cut off relay please randolphtpr Problem Diagnosis 4 08-04-2008 04:41 PM
Fuel Cut Off To Early. Cut Off At 6500rmp outsider6 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 08-08-2007 04:39 PM
Anyone know why production stopped? AmErIcAnMuScLe813 F1 9 07-09-2006 02:15 PM
AC fan makin noise, anyone know why? AtomAton '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 07-02-2003 12:53 PM
Fuel cut off or not enuf fuel? quiXilver '88 - '91 Civic | CRX | Wagon | Shuttlee 5 05-18-2003 08:18 PM
