Old 03-26-2003, 09:04 PM
Chain's Avatar
Chain Chain is offline
Spray from can or spray gun?
I have both the gloss finish super clear coat in spray can and in bottle form.
Was wondering, if you have a choice:
1)Would you use your spraygun instead of the spraycan to finish your job?
And why?
2)Will the spraygun give a finer finish as opposed to the spraycan?
3)Is it ok to use the gloss from the bottle without adding anything like thinners to it?
To each his own!
Read the FAQ you faqer
Evo Meet....coming to a forum near you!
Completed!-Click on Pic:
Projects done and posted:
Subaru WRC2001 RGB-My first project in AF Click Here
In stocks:
Ferrari F1 2001
Tyrrell P34
CLK Warsteiner
Ford Performance Blue
Ferrari Enzo
Opel Team Holzer
Williams FW24
Old 03-26-2003, 11:34 PM
Ragnarok043's Avatar
Ragnarok043 Ragnarok043 is offline
Send a message via AIM to Ragnarok043
id go with the spray, it should atomize the paint much better than a spray can. if you dont thin it properly it will spit the paint leaving a grainy finish.
Old 03-26-2003, 11:44 PM
exhaust smoke's Avatar
exhaust smoke exhaust smoke is offline
Personally I use automotive/Tamiya spray cans. This is because I match the same make clear to the paint and primer.
Also it's because I have not used an airbrush long enough to be good at it:hehehe:
For those who are well versed in the use of an airbrush, you have a better control over the flow of paint, etc.
Old 03-27-2003, 06:28 PM
Chain's Avatar
Thanks guys.
My 1st Project with the SUB, I didnt spray any gloss coat at all.
With my 2nd project, I definitely want to gloss coat my merc after putting the decals on. So I just want to make it right and wanna make sure that I look at other angles to get the job done right too.
To each his own!
In stocks:
Ferrari F1 2001
Tyrrell P34
CLK Warsteiner
Ferrari Enzo
Opel Team Holzer
Williams FW24
Old 03-27-2003, 06:34 PM
freakray freakray is offline
AF Modelrater
By spray gun, do you mean an airbrush?
Depending on the make of clear coat, whichever is the better make I would use, like if it was a spray can of Tamiya clear, that is the one I would choose. If not, whichever is better.
Before you go clear coating over decals, you may want to make certain your clear coat is compatable with the decals, as some clear coats will attack the decals and damage them.
AF User Guidelines
Old 03-27-2003, 09:13 PM
Chain's Avatar
Oops my bad, its airbrush if described in modeling terms for a better understanding
Well, both are by Gunze Mr Hobby (I'm in the office right now so I cant double check) The bottled gloss is definitely by Mr Hobby but the spray can hmmm, not sure. I'll check later.
I guess the only way is the hard way and try both gloss and see how the effects are.
Thanks freakray.
To each his own!
In stocks:
Ferrari F1 2001
Tyrrell P34
CLK Warsteiner
Ferrari Enzo
Opel Team Holzer
Williams FW24
Water sprays from muffler cheboing Fiero 3 09-12-2007 08:57 PM
water spraying from exhaust bigmacsc1 Frontier | Navara 1 04-29-2006 08:56 PM
Painting Bumbers with Paint Can Sprays Techventure General Discussion 2 04-29-2006 06:56 AM
spray from your fenders, wiper nozzles.... macavelli04 How-To's and Walk-Through's 5 02-28-2005 09:45 PM
dupicolor automotive spray and tamiya spray Thing-A-Majig Car Modeling 4 06-30-2002 02:56 AM
