Old 06-29-2002, 05:02 PM
Thing-A-Majig Thing-A-Majig is offline
dupicolor automotive spray and tamiya spray
hi guys. are these two paints compatible? i was planning on using tamiya as a base coat then going over it with the dupicolor, and then using tamiya's clear coat on top. have any of you tried this without any problems?
Old 06-29-2002, 05:46 PM
djmr2's Avatar
djmr2 djmr2 is offline
i don't think it should be a problem...
the tamiya is a synthetic lacquer, the duplicolor is a regular lacquer.... lacquer over a synthetic lacquer should be ok...
but as always, you might want to test on a scrap piece first and see what happens..
oh.. and wear a respirator
Old 06-29-2002, 06:46 PM
daggerlee's Avatar
I don't mix brands normally, but it could work. You just need to test whatever you're doing on a scrap piece of plastic first.
Dan
Old 06-29-2002, 07:09 PM
djmr2's Avatar
also
put the base coat on and then let it cure like maybe a week or longer so the gases have enough time to escape before u put the next coat
then do the same for the top coat and then the clear..
Old 06-30-2002, 02:56 AM
ales's Avatar
ales ales is offline
Forza Schumacher
Duplicolor paint is acrylic, and the only thing it goes over is acrylic paint. So I would expect it to be quie bad when trying o go over Tamiya spraypaint.
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
