Go Back   Automotive Forums Car Chat > Racing > Street Racing
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-25-2003, 02:49 AM
Stiwrc Stiwrc is offline
Honda Civic with a Prelude 22 v-tech engine
Hi ppl. I have a honda Civic '94 model 2 doors and I am thinking of installing a prelude '94 22 v-tech engine (H22A1). What do I need? Are there any risks/damages? What else I need to ensure safety and reliability of my vehicle?
Thanks In Advance
George
Old 03-25-2003, 03:15 AM
TatII TatII is offline
hmmm you have a Sti RA version IV, and you still want to drop in a big motor into your civic? hmmmm it still wouldn't be as fast. i wish i could tell you the answers, but i'm not too sure, all i know is that you gotta bang out the metal around the engine bay for the engine to fit in. also you gotta say bye bye to your a/c compressor and power steering pump cause they will not fit.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 03-25-2003, 05:16 AM
carrrnuttt's Avatar
carrrnuttt carrrnuttt is offline
There's a couple of shops here in Phoenix, including my buddy's, that can do an H22 swap in a Civic and keep the AC. It'll be an extremely tight fit, but it's possible.
The least of what you'll need is a set of custom motor mounts.
2002_Nissan_Maxima_6-speed
Old 03-25-2003, 12:44 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
www.hasport.com
www.placeracing.com
they've got kits to put it in there.
Old 03-25-2003, 02:55 PM
BeEfCaKe BeEfCaKe is offline
Another problem other than the tight fit is weight distribution.
Old 03-25-2003, 06:41 PM
if you're putting that motor in a civic, it's about going fast in a straight line...
handling isn't as big a concern...
Old 03-26-2003, 02:29 AM
NSX-R-SSJ20K's Avatar
NSX-R-SSJ20K NSX-R-SSJ20K is offline
Send a message via AIM to NSX-R-SSJ20K
if you buy a set of amps and subs you can put then in the back for ballast
no doubt it would increase the center of gravity either way you're at a loss
maybe a B16 is better?
Qualified Automotive Engineer
Old 03-26-2003, 04:54 AM
yup, i always tell my friends taht, if your goin to put a prelude engine in your civics, you better put some damn weights in the back to balance the car back out.
94 Acura NSX
Best E.T. 13.559
Old 03-26-2003, 12:47 PM
Yeah that's what I meant by the weight distribution.
If the car was solely for drag racing, then it would be fine. But as an everyday driver, the weight distribution would make the car really difficult to control.
And as those others suggested, adding weight... sure it would help balance, but that would defeat the purpose of putting the 2.2L engine into a light civic chassis. Why not just buy a prelude instead?
Old 03-26-2003, 01:33 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
So does anybody know the weight difference between a B16 from that of a H22?
I'd like to know how off balance the H22 would make the Car... I have a feeling its not much difference.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 03-26-2003, 02:38 PM
from what i've seen, it's about 100 pounds... maybe a little more...
it'll cause some understeer though...
Old 03-26-2003, 04:02 PM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Adding more weight to the car is NOT the answer. What you do is upgrade your suspension and lose MORE weight from the front of the car, not add weight to "balance" it out. That completely negates the added power you'll get from the engine.
There's no replacement for displacement...No, not even a turbo.
Old 03-26-2003, 04:08 PM
well what my friend is doin with his crx right now is that he striped the entire car, and then added a sound system in the back to offset the weight overall. i dunno, it seemed like it might work. however yes i realized that it defeats the whole point of putting a bigger motor in a lighter car if your goin to just add more weight to it. oops. but non the less, that year civic still weights around 450lbs lighter then a prelude. so even if you add some weight, it should still be a good amount lighter then a lude.
94 Acura NSX
Best E.T. 13.559
Old 03-26-2003, 05:50 PM
True. But even IF you managed to fit it in, it'll be very tight and it'll be difficult to install further mods such as turbo.
Old 03-27-2003, 03:38 PM
$ilverbullet $ilverbullet is offline
Send a message via AIM to $ilverbullet
Re: Honda Civic with a Prelude 22 v-tech engine
Originally posted by Stiwrc
22 v-tech engine
u know what's funny? some people can't spell "vtec". Correct me if i'm wrong but isn't "vtec" Variable Valve Timing and lifting Electronic Control?
My 1993 240SX SE Fastback
Closed Thread
