Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-20-2009, 02:37 AM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
Indexus Metrogloditus
I am starting this ongoing thread in order to form some sort of INDEX with
links to threads within the Geo Metro Forum by subject.
This Thread will have posts (locked) with subjects like
Engine Rebuilds
Wheel Bearings
Transmission Rebuilds
Throttle Body
Exhaust System
Cooling System
Electrical System
on and on
Each with links to threads from enthusiasts who posted here.
This is an experiment - I hope it works out...
It is obvious that most folk visiting this Forum do not do a Search prior to posting questions.
Maybe this Index will help them find answers without having to ask questions
and wait for someone to answer.
There is a vast storehouse of information already within this Forum.
I will be constructing it and editing it as time allows - always changing things.
I have a lot of searching to do !
Pray I don't screw it up.
NOW - If anyone thinks a particular Thread contains good, complete information,
you can Private Message (PM) me with the link and the Title in your message
and I will have a look.
If I think it is worth it, I will enter it into the new INDEXUS METROGLODITUS stickie at
the top of the Forum.
PLEASE - don't send me links filled with trivial, partial, silly stuff !
I hope I don't live to regret the above request....
DoctorBill
Old 01-21-2009, 12:06 AM
DOCTORBILL's Avatar
Geo Metro Lover
This will be edited from time to time - Links added and ordered. Be patient...
Click on the Blue link...(The Links in a subject are in no particular order)
Axles
Part of link devoted to removing the CV Axle
http://www.automotiveforums.com/vbul...d.php?t=907782
Rest to removing the Transmission.
Frame - Body
Window Regulator Repair (Photos)
Body - Corrosion Damage
Trunk Struts - Problems
EGR VALVE
ELECTRICAL
How To Replace The Door Switch 95'+ geo/fly (Photos)
95 Geo wiring issues
Timing Light - Jumping the "Duty Check Data Link Plug" (Pictures)
Geo Metro Distributor O-Ring Seal - Size & Part Numbers
ENGINE - 3 CYLINDER
Changing the Timing Belt
Timing Belt & Timing Information
compression (Test) on a 1.0
Compression Test
Head Job/Ring Job
Metro 1.0 Automatic Engine Rebuild (Photo's)
1.0L Head removal guide (Photos)
Cylinder Valve Job
NOT the end of my '93 metro...Life after death! RINGS (Photos)
The Flight of the PHOENIX !
GAS MILEAGE - POLL
Poll - What is your Metro's Gas Mileage?
INTAKE MANIFOLD
A way to Clean the Carbon out of the IM Passageways (Photos)
How do you clean the Carbon out of the Intake Manifold Gallery? (Photos)
Nut & Bolt Jar
"Sea Foam"
TRANSMISSION - MANUAL
5 Speed Transmission Rebuild Manual
You might consider downloading each page to your Hard Drive to have on hand !
Alternate Gear Oil Filler Hole (Photos)
Trans/Clutch Removal Guide 1995-2000 (Photos)
Fixing a Tranny Leak (Photos)
Some trick to inserting the speedometer cable in the Transmission?
Manual Transmission Oil - 1
94 Metro 5 Speed Manual Transmission Rebuild - Part 1 - Disassembly (Photos)
-END-
Closed Thread
