| Latest | 0 Rplys |
02-22-2009, 09:04 PM | #1 | |
Trunk Struts
I am wondering if I may have the wrong trunk lift supports on my 95
2 door hatchback, I bought some replacements but when I looked at them next to what is on the car now, they are a lot shorter, they probably would fit but would not extend as much, if any one out there could measure the length of the trunk struts fully extended I would appreciate it! |
02-24-2009, 03:40 PM | #2 | |
Geo Metro Lover
Re: Trunk Struts
They are easy to remove.
I can measure mine when I get home from work and let you know. However, this is a problem for EVERYONE with a hatch.... They cost an arm and a leg new. I have "obtained" several at the Pull & Save, but they almost always are just as bad as mine are. Mine crap out in cold weather and I use the old proverbial broom handle which I always carry in the back of my '93 hatchback. I'd like to figure out a wood rod system on a hinge at one end and some type of clip at the other so that I can just prop the hatch up. Maybe one of those super strong Rare Earth MAGNETS glued or embedded in the broom handle end and a hinge at the other. You could put the hinged end on one end of the hatch and have the magnet end stick to the hatch. Just pull it off and prop the hatch up. When closing the Hatch, let the magnet stick to the hatch when you rotate the stick back up before closing the hatch... Paint the Broomstick so it is "puuurdy".... It could work....! DoctorBill
02-25-2009, 07:06 PM | #3 | |
Re: Trunk Struts
DoctorBill,
I posted a while back about a device designed for just this purpose. http://www.automotiveforums.com/vbul...d.php?t=930481 I finally went to Advance Auto today and picked one up for $8.49, and I have to say, it is possibly the most ingenious device ever made. Works perfectly and is more stable than I imagined. It's universal, comes with 3 different clamps to fit different sized strut rods, and the prop must be cut to length. Even comes with a little miter box and saw blade to cut it perfectly. Much more convenient than my former device. |
02-26-2009, 03:45 PM | #4 | |
Geo Metro Lover
Re: Trunk Struts
I Googled Advance Auto and found out that it is not on the West Coast...
http://advanceauto.know-where.com/advance-auto-parts/ I looked under "PartsAmerica.com" (Schucks here in Washington) but couldn't find "LiftLock".... Then I printed Rooy's photo and looked at the name more closely. Made by "Pylon" and it is by Pylon that you have to search ! http://www.partsamerica.com/ProductD...artNumber=8200 I am on my way to Schucks here in Spokane (Eastern Washington State) to by one or two of these gems... Thanks Rooy ! Nice. DoctorBill
02-26-2009, 04:21 PM | #5 | |
Re: Trunk Struts
I used those for many years on one of my cars. Word to the wise, if you loan out your car, or let someone help load stuff into the rear, make sure to point out how they work, or you will be replacing them after they get broken.
02-26-2009, 07:39 PM | #6 | |
Geo Metro Lover
Re: Trunk Struts
I guess today isn't my day.
Went to Schucks with the PartsAmerica part number and Rooy's Photo. No gots! In fact Schucks and PartsAmerica are parting company come march 1st. But - something really nice came from this. A salesperson at Schucks said, "Why buy this junk, when all you need is a section of ABS or PVC Water Pipe...?" I was told to cut some plastic water pipe the length of the Strut's Piston Rod, take the Strut off and run the pipe over the strut, then re-install the strut. When you open the Hatch, lift the PVC pipe up over the rod and let it rest on the strut. The Hatch cannot close as the plastic pipe prevents the strut from closing. Lift the Hatch a bit, move the plastic pipe and let it drop over the Strut and close the hatch. I about crapped myself ! So elegantly simple - yet perfect - and CHEAP. You can spray paint the plastic pipe black and it will hardly be noticeable. SO...I went home and tried to take off the strut....no way. The Metro Struts cannot be disassembled. Could not get the Ball out of the bottom end and the Top Hinge is riveted onto the rod end. So in desperation, I cut the PVC plastic Pipe lengthwise with a hacksaw blade. Then I put the Strut back on the Vehicle and spread the cut side of the PVC Pipe to allow me to force it over the rod lengthwise. It is pretty tough. Here are photos of how it worked - QUITE WELL. It snowed last night, so these photos have snow in the background. You can't get any cheaper and more elegant than this. ...and if a club fingered, porcine oinker like me can do it - anybody can! Gravity keeps the Plastic Pipe up against the top of the Strut because it is at an angle while open - neat. It is essentially unbreakable. I think folks used to use this sort of thing on screen door closers - to keep the door open.... Also - I am going to put this on BOTH STRUTS just in case I bump the pipe. The Hatch could fall with only one - but two would hold it up even if bumped... I had only One Inch PVC Pipe, so when I can find some one half or three quarters inch, I will replace what you see. What I have is maybe 1/2 inch too long also. Has to be large enough to slide over the Strut and I didn't measure the Strut's diameter - t'were cold out there ! I want to emphasize - this was not my idea. It came from someone who works at Schucks. DoctorBill
02-27-2009, 01:52 AM | #7 | |
Re: Trunk Struts
what i do is even cheaper. i put a very slight bent in the strut rod where it goes into the cyl. i just grab the rod and pull toward me a little, you only want about 1/16" bend in it or it will be to hard to open or close. done it to several metros and seems to be working just fine. just remember don't pull real hard and bend it to much or hatch won't close
02-27-2009, 05:42 AM | #8 | |
Re: Trunk Struts
Great idea. I also like that you can paint to match.
One question,,,,, does it rattle when driving? |
02-27-2009, 09:58 PM | #9 | |
Geo Metro Lover
Re: Trunk Struts
I drove to work today and it does rattle.
I wonder how I can fix THAT...? I used it when I went to the store and loaded something in the Back. Worked nice. If I could get that damned Ball joint to come out, I could use a lesser diameter plastic pipe. Must need some "Special Tool" to take out that wire holding it in... DoctorBill
02-28-2009, 01:51 AM | #10 | |
Re: Trunk Struts
actually its kinda crimped in, just use a 12mm open end wrench and unscrew it from the hatch
02-28-2009, 11:21 AM | #11 | |
Geo Metro Lover
Re: Trunk Struts
Sorry..that is not what I meant.
I had the whole strut out of the vehicle and the ball joint sticks out at right angles to the strut. That fact keeps anyone from sliding the plastic pipe over the Strut. I tried to "pop" the ball out by levering on it, but that doesn't work - it is in there ! There is a wire "Keeper" inside the hole above the Ball joint and some slits on each side of the Ball - but I could not remove the wire or the Ball. Brute force did not work - just bent the washer around the bolt. If one could temporarily remove the Ball, then one could slide a lower diameter plastic pipe over the strut, put the Ball back in and this idea would work even better. If anyone knows how to get that Ball out - please let us know ! DoctorBill
11-14-2012, 01:44 AM | #12 | ||
Re: Trunk Struts
Last edited by shorod; 11-14-2012 at 12:53 PM. Reason: Apparent attempt at advertising. Use Private Messages for offline contact. |
11-14-2012, 01:49 AM | #13 | ||
Re: Trunk Struts
Thanks, Lou Fishman Last edited by shorod; 11-14-2012 at 12:53 PM. Reason: Apparent attempt at advertising. Use Private Messages for offline contact. |
11-14-2012, 01:58 AM | #14 | ||
Re: Trunk Struts
Last edited by shorod; 11-14-2012 at 12:54 PM. Reason: Apparent attempt at advertising. Use Private Messages for offline contact. |
