| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
7th gen hondas
I want to knw if anyone has seen or knows about possible easy swaps for the 2001 to 2003 civics. not the si cause I know you can put that engine in. Im talkin H22a or B18 or or the accord engines and if there are kits or ways to put these in. Im also looking for websites that i can order engines off of. Im also thinking about geting a crv could i put a gsr or ls engine in it for turbo or supercarging purposes. AND if i do so can i order the engine with trans or without for a civic. what engine mounts do i need. LIKE THIS IDEA A K20a rsx type r motor in a CRV
will this work. IM I NEED OF SERIOUS HELP HERE THANKS. o yeah heres the enginesim think about for the 7th gen civc (same motor for crv) 30010 - K20A (RSX Type R) Motor, Tranny, ECU 220 Hp 158Trq 11.5 Compression (JDM) $ 5800.00 Plus shipping and handling. This is for both cars also 30005 - B18B 94-01 (LS) Complete Change Over 145Hp 127Trq 9.4 Compression (JDM) 142Hp 127Trq 9.2 Compression (USDM) $ 2200.00 Plus shipping and handling. and maybe this ( for crv) and will it fit in a accord sedan 30008 - F20B 97-00 Complete Changeover (Accord SiR-T) 200Hp 145Trq 11.0 Compression (JDM) $ 3500.00 Plus shipping and handling. ALL i want to know is if those engines will fit in these cars: 2001-2003 civic 97-00 CRV w/o the trannys in case its 4wd 97-2001 Accord Thanks for stickin with me!!!!!!
O and i looked at the site more and just now looked at OBDI and OBDII can some one help me with this also! This Is what I want from u with the awnser:
1. If it will fit( which cars) 2. Mounting trans or onto trans yes or no 3. any other info ( FI options and other things that i need to know in order to make it work right) THanks |
There is one motor that swaps into a K series,and that is another K series.The other rotate the other way,and don't have any gains worth anyone going through the trouble to custom fabricate mounts.Not to mention the OBD issues would kill you.If you have to swap into a CRV,why on earth would you put in a weaker motor?Hello,the CRV motors have "torque" to move the beast.Also your talking about swapping H and K and B series trannys and motors and that doesn't work,the parts don't bolt to each other.Sorry,but the answer is no don't do it.
yeah u right
but cant i put the F20 in a honda accord 4cyl? The GSR has 126trq and a supercharger could put it at about 142 right!!! and a turbo could put it at 150 trq and that should bolt on to the crv trans AWD right?? what sould I get if I was to build the civic since I cant get a motor for it what should i do!! same with the CRV !! and what engine for the accord!! O yeah how manyt liters is the accord v6 3.0???
I know I fell stupid i thought it was 3.5. dughhhhhhh so anyway
Really there is no easy way to do it.Anything can be done,but at what cost?that is the issue and what you are talking about would be very expensive and a true head ache with the wiring and fabricating of mounts.
hey can i put a non vtec head and block on the b20 then put a turbo or supercharger from that??? if so what block and head or do i just need one or the other
Help me understand I m only 14 |
www.hondaswap.com register and read the articles.you can learn a lot there.
You would,be losing a lot of power by putting a nonvtec head on a vtec block.The vtec rev higher and have better flowing heads.
so i can just bolt a b18 or b16 head on and buy a turbo that matches the series of the head, simple as that or what else do i need to make it happen???
Not even close,go to a search engine and search for lsvtec or crvtec.
