Old 03-21-2003, 06:38 PM
nornicle nornicle is offline
Send a message via ICQ to nornicle
CF decal application FAQ? Q for Pman
I have read some websites etc and read the back of the scale motorsports CF decal sheet, however I still don't understand how to get the *exact* size of the area its being applied to.
e.g if you see tamiya's enzo model they use CF decals on the engine etc etc..
however they get it so exact? how do they do it? does the modeller have access to the CAD?
Pman - how do you detail stuff, for example your seats in your enzo have red on them and then black on the back (as per instructions)
the line between the colours are very clean, how do you achieve that?
is it the same as your window frame painting (careful masking and enamel?)
Richard
nornicle@\/ahoo.comau <br>
Old 03-21-2003, 07:00 PM
RallyRaider's Avatar
Zomby Woof
Re: CF decal application FAQ? Q for Pman
I generaly don't try to get the CF decal the exact size of the part to be covered. Instead I cut the cut the decal so it is larger than the area, apply it, then when dry cut the excess away with a sharp knife.
Another method is to cover the area with masking tape first. Use the knife again to cut the excess tape away then use the leftover masking tape as a template. I think that is the technique Mathew Wells of SMS uses to make his templates.
Old 03-22-2003, 02:21 AM
flyonthewall's Avatar
Car Mod guy
Re: Re: CF decal application FAQ? Q for Pman
Ditto
Old 03-22-2003, 04:13 AM
CADguy's Avatar
CADguy CADguy is offline
I use masking tape to make a template first.
I paint all parts gunmetal before CF decaling, if you make any mistake, or the decal doesn't quite cover the entire piece, you'll never notice it.
Matt
FAQ for SRT-4. MUST READ! Turbodog97 SRT4 Problem Diagnosis 0 09-04-2006 05:38 PM
Best Spark Plug FAQ for DSM !! ( Thanks MrBoxx ) Killa Engine, Transmission and Drivetrain 4 07-13-2006 12:29 PM
Decal application and polishing compound geofroley Car Modeling 0 05-24-2004 07:08 PM
Hasegawa Decal Application freakray Car Modeling 10 01-14-2003 07:03 PM
