| Latest | 0 Rplys |
#1 | |
Low Coolant light on 97 LS Regal
I have a 97 Regal LS, 173kms and am seeing the "Low coolant" light come on intermintely. There are no leaks under the car. The cooling system was flushed in early 2008 and thermostat changed. Water pump changed 2005.
The temp gauge is always at normal once the car has driven Just to mention the coolant bottle brown hose has broken off. Could this be affecting the readout and triggering the low coolant light to come on/off? Any suggestions/ideas appreciated |
#2 | |
Re: Low Coolant light on 97 LS Regal
#3 | ||
![]() Join Date: Jan 2005
Also, some old Dex-cool sludge regardless of the flush can cause contamination of the level sensor located about 3 inches below the radiator filler neck or the sensor could be bad. See pic below. You can access the level sensor by removing the passenger side headlamp assembly. ![]()
