Old 03-20-2003, 03:50 PM
Smoakie976's Avatar
Smoakie976 Smoakie976 is offline
Angry vtec not working
My vtec is not working and I do not know why...can someone help me...I swapped a b16a2 and the vtec was working, but now it just stopped for no reason and it pisses me off! I check the plug and cleaned it out and it worked for a few days and the stopped again...I am not sure what the fuck it is! Can I have someone expertise?
Thanx
Old 03-20-2003, 04:11 PM
jcxcr4000's Avatar
jcxcr4000 jcxcr4000 is offline
Send a message via AIM to jcxcr4000
check the vtec solenoid
Old 03-20-2003, 04:20 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Check your oil level.
Old 03-20-2003, 10:52 PM
BrokenLimits BrokenLimits is offline
Send a message via AIM to BrokenLimits
Definitely your oil level...Whens the last time you changed your oil?
Brandon
Columbus, OH and Orlando, FL
2000 Civic Si with fully built LS VTEC
Old 03-21-2003, 12:07 PM
Smoakie976's Avatar
not the oill....I have a few weeks left before I change it and the oil level is good too......how do i check the solinoid?
Old 03-21-2003, 01:29 PM
Are you getting CEL code,if so have you pulled the code,if so is it 21?
Disconnet the plug from the solenoid and check it with a multi meter it should read between 14-30 ohms,when you look into the plug,your going to see to prods the small one is the one you check.You can road test it also,accelerate in 1st gear to a engine speed of over 6000 rpms,hold for a least two seconds,if you don't get a CEL do it two more times,if your vtec isn't coming on and your not getting a CEL then check your solenoid as above and you also have a loose wire or intermittent failure somewhere else in the system.Remember,your car has to be at operating temp for your vtec to work,so before doing the test,drive around for a bit.
Old 03-22-2003, 01:06 AM
Smoakie976's Avatar
how do I find out to get a cel code? I am new at this bear with me!
Old 03-22-2003, 05:11 AM
luti luti is offline
Send a message via AIM to luti
CEL's are when your check engine light comes on in the dash. If you want to check the code you have 2 options, 1.) go to autozone, they'll do it for free, or 2.) if it's obd2 you can jumper it with a paper clip and read it that way (look this tactic up on google, I can't explain it, but it's very easy).
T3/T04E turbocharged ricer.
Old 03-22-2003, 11:17 AM
Jump the 2P Service Check Connector located behind the right kick panel you can read the DTC with a Honda PGM tester, OBD-II scan tool or by watching the Malfunction Indicator Lamp (MIL), commonly referred to as the Check Engine Light (CEL). The MIL will flash a number of long flashes equal to the tens place of the DTC, then a number of short flashes equal to the ones place in the DTC.
For example, eight long flashes and six short flashes equals 86.
To clear up any confusion: Code 01 is equal to one short flash, Code 10 is equal to one long
Old 03-23-2003, 09:20 AM
Smoakie976's Avatar
Hey could there be a problem if my O2 censor is not hooked up.....my check engine light is always on so I don't know if I am getting a cel!
Old 03-23-2003, 12:08 PM
That's why you need to pull the codes,You get a steady CEL till you jump it and then it will tell you what all is wrong.
Old 03-24-2003, 12:39 PM
Smoakie976's Avatar
I just took it to the shop and the buy told me that he will look at it on Saturday for like 25 dollars! Sweet huh?
1998 honda civic ex
b16a2
AEM intake
HKS HiPower Exhaust
Skunk2 front camber kit
2000 Si rear bumper
99 Si wheels
pioneer p9000 head unit
jl audio w6 12" sub
Rockford Fosgate 250x2 amp
976 Crew
Old 03-24-2003, 01:31 PM
I'm going to put money on it being that you are running a GSR ECU that is looking for a IAB signal that it isn't getting from the B16A2.Also if your o2 isn't hooked up that will do it also.
Old 03-24-2003, 09:42 PM
Smoakie976's Avatar
what the fuck is an IAB signal?
1998 honda civic ex
b16a2
AEM intake
HKS HiPower Exhaust
2000 Si rear bumper
99 Si wheels
jl audio w6 12" sub
976 Crew
Old 03-25-2003, 10:26 AM
GSR engines have a set of secondary Intake Air Bypass butterflies that are activated at high RPMs to let in more air.GSR ECU's look for this signal from the IAB solenoid.If your running that ECU and it hasn't been chipped to bypass that function,it is still looking for that signal and is going to throw a CEL.
vtec not working yet working topbro2 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 03-29-2006 06:35 PM
VTEC not working Smoakie976 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 24 01-18-2004 03:00 AM
Vtec not working and some other things, someone help! atrain598 Engineering/ Technical 1 10-28-2003 04:11 PM
Vtec not working!? (Again) 5_LiTeR_EaTeR Engineering/ Technical 2 06-20-2002 09:56 PM
Vtec not working!? 5_LiTeR_EaTeR Engineering/ Technical 6 03-25-2002 09:10 PM
