Old 03-02-2006, 09:56 PM
Moze's Avatar
Moze Moze is offline
Need help with intake issue...
OK...I got the True Flow intake kit today. I was sure to remove the negative battery cable so the PCM would 'reset' prior to installation. It runs good wide open, but when idling, it acts like it's going to stall. A couple of times when I was slowly turning corners, it DID stall. Does anyone have a clue what the problem might be? Everything appears to be tight...so I'm stumped. Ideas?
Old 03-03-2006, 06:32 AM
B18B_EG6 B18B_EG6 is offline
Re: Need help with intake issue...
make sure you have a good seal on everything, if its not hooked up completely you can get an air leak, this will throw off the mass air flow sensor and it will want to die on you. but my guess is an air leak or soemthing to do with the sensor.
Old 03-03-2006, 07:13 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Did you plug the MAF back in? I forgot to do this when installing mine
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 03-03-2006, 11:46 AM
Moze's Avatar
I'll be sure to check both of those things and post back if that's not the problem. Honestly, I didn't unplug the MAF sensor. Was I supposed to?
Old 03-03-2006, 01:06 PM
Moze's Avatar
OK...well, I checked everything just to be sure it was tight. It was, but I undid the clamps anyway and retightened/rechecked. I undid the negative cable again for about 15 minutes, then reattached it. Took it for a drive and turned into a parking lot and it stalled. Started it, went to make a turn in the parking lot - stalled again. Slowed down to pull into a parking spot - stalled again. Went in the store, came out and it stalled at two stop signs. After that it seemed to be a little better, but still seems to idle a little rough. When I come to a stop, the idle drops to about 300 rpm, the levels out at 500 rpm.
So, any other ideas? Can some of you let me know what your trucks idle at? I think 500 is about normal, but just want to compare.
Thanks in advance...
Old 03-03-2006, 02:19 PM
2000CAYukon 2000CAYukon is offline
Is the check engine light on? The MAF is directional so you want to make sure you have it installed correctly.
Idle should be 550 in Drive.
//2000CAYukon
Old 03-03-2006, 02:35 PM
Moze's Avatar
Nope, no check engine light. And yep, the MAF sensor is installed correctly. Idle seems to be a bit low. So I'm still stumped.
Old 03-03-2006, 07:18 PM
Moze's Avatar
Well this may be of help to others down the road...
It seems like the low idle and stalling problem has corrected itself. So maybe the computer just had to make some internal adjustments. I don't know. I talked to True Flow and he said if I have any more problems, to try disconnecting the negtive cable, reconnect it, start the truck with the A.C. off and let it run for 5 minutes. Then switch the A.C. on and let it run an additional 5 minutes. HE said that should help the computer establish the base line idle.
Anyway, thanks to all for their input and help.
Old 03-03-2006, 07:41 PM
anytime you remove a battery cable you need to start the truck and let it run with all accessories off for at least 5 minutes without touching the gas pedal before you drive it so the computer has a chance to map fuel curves and set baseline data.
Old 03-03-2006, 09:00 PM
Moze's Avatar
Very good to know - thank you! (See, learn something new every day...).
So since it seems to have leveled itself off fairly well, should I start over by removing the cable and follow the procedure you mentioned?
Old 03-04-2006, 06:35 AM
if its running ok it should be fine. it will remap over time and make fine adjustments so it should be ok. but if are having any trouble or your gas mileage seems to be low try resetting it again. it cant hurt anything if you do. anytime i do any work to my truck i reset the computer. (new plugs, wires, k&n air filter, and so on) as long as it is something that relates to engine operation. i probably dont need to reset it that often because the computer will learn it over time.
