Old 03-10-2003, 08:05 PM
5.0VIPERMAN 5.0VIPERMAN is offline
Send a message via AIM to 5.0VIPERMAN
Rear-end question
Does anyone know how much it costs to get 3.73's put in at a dealership?
1991 Mustang GT vert...1 5/8 shorty headers, offroad h-pipe, flowmaster mufflers, CAI, ported and polished lower manifold, 3.73's, Tremec 3550, King Cobra clutch, Pro 5.0 shifter, electric fan, subframe connectors, Lakewood upper control arms....A LOT more to come.....if only money grew on trees...14.2@95 mph 221 rwhp and 278 rwtq
Old 03-11-2003, 04:23 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
It all depends on where you go and what your having done. I've heard of people having gears swapped for about $150, but that's just labor cause the person supplied the gears. I paid about just under $700 for mine. This included the ring and pinion, crush sleeve, all new axle bearings, rebuilt my burnt clutch pack, turned the axles to ensure straightness, new Speedo gear, and gear fluid. So it really depends on what your having done, and where.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 03-11-2003, 02:43 PM
94svt5.0's Avatar
94svt5.0 94svt5.0 is offline
My car is in the shop right now getting 3:73s redone with a fresh gear set. I made the mistake of going to the cheapest bidder and providing the gears. The place screwed up the install causing the gears to become damaged and then claimed the gears where defective to cover the whining and jerking issues and get out of covering the problem. I called a bunch of places this second time, the local ford dealer wanted $900 for just labour I ended up taking it to a performance shop and let them provide the gears. So, new gears all parts, new bearings and a new auburn limited slip unit with labour is going to cost me $950. All covered with a 12 month or 12k mile warrenty.
Basically it is usually not a good idea to skimp on money. Take it to a good place and DONT provide the gears.
More photos and Info/website!
1994 Cobra
-off road h-pipe
-superchips power chips
-mac cold air induction
-BBK aluminum underdrive pullies
-pro-m 75mm bullet MAF
-18" konig wheels with nitto 555 zr tires
-Ford Racing 65mm throttlebody
-Ford Racing king cobra clutch
-Ford Racing 3:73 Gears
-Ford Racing Aluminum driveshaft
-Bullit suspension/ springs,shocks,struts
-Aubrun HD limited slip Diff.
2002 subaru Impreza RS
- stock
1989 Toyota pickup 4x4
-K&N
Old 03-11-2003, 04:42 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I would never have something like that done at a dealer. Unless you know someone who works at one or there is a guy who works there that is a mustang junky. Dealers usually charge to much for any type of upgrade cause they don't want to do those sort of things. Your much better of finding someone you know who has had it done in your area and is happy and have it done there. As far as price... I did my own 4.10's but around here I know people who have had it done for $150 and some as high as $700. Both situation they have never had a problem. So just ask people in your area they will point you the right place to go.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 03-11-2003, 06:21 PM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
dudes, you guys are scaring me. I just got those 3.27s and i was thinking about putting them on myself using the ol' Chilton. Is it possible for two semi compitent guys to figure out how to do it right? Is it riskey bussiness, like if we mess up a little could it really fowl things up? I don't mind paying extra to have it done professionally, but i kind of want to do it alone to get the experience.
Old 03-11-2003, 09:48 PM
GTStang's Avatar
Stang Guy
I think you should do it but I never shyed away from doing it myself. Now I get paid to do it. My suggestions would be honestly look at how car savy you are. If you have never done too much besides bolt on stuff. This probably isn't a good first project. If you think your ok, i say make sure to read page by page and where it says take measurements do it!. Worse case if you fuck it up, you'll shred a nice new set of gears.
Old 03-11-2003, 10:34 PM
good advice, highflow, what's your take on the matter?
Old 03-12-2003, 04:52 AM
HiFlow5 0's Avatar
Stanger
Don't even bother doing the swap if your going to install 3.27's. That's just my opinion, not worth the hassle and money for a little gain.
Actually I'm going to have to agree with GTStang on this one. It might not be a good project if you have never done something like this before. Lots of things can go wrong without you knowing. Backlash must be perfect or you will get an awful whine. If gears are installed properly then there should be no whine at all. Also not to mention if your doing this in your driveway then its going to be a hell of a lot harder. You might need use a breaker bar about 5 feet long to get the pinion nut off and on, kinda of hard to do on jackstands. Then getting the ring gear torqued properly will be tricky as well.
Then again if you mechanically inclined and have access to a dial gauge and all the proper tools, knock yourself out. Just plan on having a free weekend to do the work.
Also one other thing to consider is having the clutch pack rebuilt. I know mine was shot and my car was peg legging before I had the rebuild. Just another reason to have a reputable shop do the work.
-2013 Ford Flex
-1999 Ford F150
Old 03-12-2003, 01:55 PM
94svt5.0's Avatar
I also would not recomend doing it unless you have the help of a mechanic who has done the job before. And be pretty certain that your limited slip is fried, very common on cars with a few miles on the clock. Mine was fried, and is getting an auburn pro unit installed at this moment.
1994 Cobra
-off road h-pipe
- stock
-K&N
Old 03-12-2003, 05:51 PM
GTStang's Avatar
Stang Guy
*SIGH* Rear-ends man, they end up being one of the most expensive things. What happens is first you decide to change gears. Then you realize my diff needs to be changed. So why go with the crappy stock unit? So now you upgrade to an Auburn or something else. Except then you realize I should get Moser 31or33 spline axles there much stronger than the 28's. Sadly it can go even farther than that, next it goes if I'm getting new axles I should make them 5-lug which you been wanting to do and you need the front 5-lugs to match. Hell now you need the disc brakes too. For good measure might as well get a nice aluminium cover/girdle to top the rear-end off and can't forget C-clip eliminators.
LOL, I don't know if there is a moral to this story...
Old 03-12-2003, 06:09 PM
HiFlow5 0's Avatar
Stanger
HAHAHAHA
The moral is to go all out and break the bank the first time!
-2013 Ford Flex
-1999 Ford F150
AWD Rear End NOISE BigBriar63 Rendezvous 1 05-10-2010 10:59 PM
1975 Caprice rear end gear/rear end swap? Topless75 Caprice 3 03-10-2010 12:29 PM
1995 Dodge 1500 rear end problems alley30577 Ram Pickup | Ram SRT10 2 02-19-2010 09:37 PM
Replacing rear end gears bigdaddyhill71 General Discussion 1 02-10-2010 09:10 AM
Rear end noise fastlane85023 Mustang Problem Diagnosis 4 11-29-2009 07:39 PM
