Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-29-2009, 09:50 PM
fastlane85023 fastlane85023 is offline
Angry Rear end noise
I recently changed the right side axle on a 91 GT 5.0 and also the u-joints and now I am getting a horrible gear binding noise from rear end. I have tore it down 3 times and redone my work and dont know what to check next. Can someone help? Is it possible I need to set end play on pnion shaft? It is a 8.8 inch posi rear end,
Old 07-29-2009, 11:33 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Rear end noise
Normally you do not have to touch the gear set up at all.
What happened to the old shaft? Was it damaged? Is it possible the inner or outer bearings are also damaged?
Old 07-30-2009, 10:55 PM
MagicRat's Avatar
Re: Rear end noise
You have sent me this note:
I also replaced the bearings. The kid the car belongs to hit a curb and bent the axle wheel plate let me know if you have any ideas.
Unfortunately, I think you may have additional damage. If the axle impact was inwards towards the differential, the axle tube, or lateral, the axle tube may be bent. If the impact was outwards, the differential carrier may be damaged.
Either way, it may be easiest simply to swap the entire rear axle, or at least take it to a shop for a professional diagnosis.
Old 11-26-2009, 09:28 AM
gary turner gary turner is offline
Re: Rear end noise
i also had the right axle replaced due to rear end noiise.didnt help so i just live with it
Old 11-29-2009, 07:39 PM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
Re: Rear end noise
Sounds like carrier bearings...
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Tags
8.8 , binding , end , posi , rear
